Polo @ Castle Combe
Just had a look on the TTRS web site, and there is a vid of Castle Combe from last year.
First race of the season straight out no testing guessed set up qualified 8th on the grid out of 30+ cars
Kept the M3 at bay for virtually the whole race.
  • Replies 25
  • Views 3k
Guy in the M3 seemed to make better use of the full with of the track on that last right hander each time and caught up a bit. Fun to see the G40 on track! Looks like close racing.
Edited by Tav
He had more than a slight advantage over me, M3 with about double the bhp, the car is light as well with composite boot and bonnet and all the air intakes etc are all carbon, he's been running it in the same spec for several years on the same tyres etc.
Me straight out on a guessed set up, on strange tyres that I have never run on with guessed pressures, the engine was in a new spec and hadn't been driven on other than from the workshop and into the truck.
The little car did good, surprised a good few of them that day, what it doesn't show is I nearly got the White 220 turbo that was running at around 100bhp more than me
Looks fun!
Out of interests what brakes does your car have?
Just thinking about the arguments people were having for and against big brakes and I guess your car sees more brake abuse than most of ours will!
Looks fun!
Rears standard drums with standard shoes and the brake bios to the front so hardly any rear brakes.
Fronts standard set up with EBC Yellow Stuff Pads, last year I changed from standard disks to some OMP grooved disks as I had them kicking about in the garage.
Braided brake pipes and what ever is the cheapest competition brake fluid I can find.
Another techy question. You have the standard 13" RA's Toyo R888's in 185/60 R13? ...but what sort suspension height?
Edited by Tav
Correct on the tyre size 185-60-13 but am switching to the 165-50-15 on a set of 15" ra's
Should give me less tyre deflection as you can really feel the car move around on the 13's due to the higher side wall's
Plus the 15's are 1.4 kilos a tyre lighter so should account for any weight difference in the rims.
Ride height wise I haven't got any exact figures but it still has it's cup suspension so sits lower than standard.
The front has shorter and heavier springs than the original Cup ones and used to clear the slicks ok but I had to machine some 6mm spacers to raise the front up to clear the 185-60-13's the rear end isn't a problem as it virtually bump rubbered solid.
Will the increase in rim size see an increase in brake disk size, or are you happy with the 239 + yellowstuff combo?
Happy with the brakes as they are. The regs allow me to fit anything that will fit under an original rim but I know where I am with them, The minute I have any issues I will look into changing them but I'm not getting any fade and can out brake lots of cars with big brake set ups so going to leave them be.
That looks totally mad. Great fun! What kind of power you running in the G ??
Over a 160+
Over a 160+
so the standard brakes work fine for you with just a few tweeks to the pads etc? interesting that like... :lol:
Edited by supercharged spaniel
cool love to have a go at that
you running any other suspension goodies other than the cup setup?
luke
luke
Nope, just the the Cup roll bar, the front dampers have had the inserts changed hence the spring change mentioned above.
Over a 160+
certainly seems to have pissed on some peoples bonfire! :lol:
loving the track action mate, good vid. id love to do somethin like that but just dont have the funding :(
you held him off well :thumbsup:
looks cool
Over a 160+
I don't have a budget to run it just have to rob the wife's account and rely on a lot of good will to keep it out
fair play to you man. my dads buying me a track day for my 21st (one of those lambo gallardo/porsche supercar things) and i know its gonna be a bad move cos it means I'm gonna go buy something and track prep it lol!
Over a 160+
I'm sure you'd love to run race brake pads on the road...
Strange things brakes.
I run EBC Green stuff pads in my daily (Scooby) and they are the best I have tried and last ages. Superb from cold no fade etc.
So I put a set of EBC Reds in the race car with the standard disks they gave superb braking but lasted one qualifying session and race at Snetterton so that equates to about 45 mins driving and down to the metal.
Surprising as they are harder then the Greens and would probably be awful on a road car when cold, it's unlikely that under normal driving they would get enough heat in them to get them working properly.
So now have the Yellows, feels very dead on the pedal, stops like the Reds but without the accelerated wear. If put in a road car I think you would have trouble getting the car to stop.
Over a 160+
Who's bon fire is pissed on now? :lol:
Onboard driver did seem to make a better job at hitting apex and exiting fast, but even still the Polo stayed infront a great deal longer than I thought it would!
I just couldn't keep him behind me any more, still took him virtually the whole length of the start finish straight to get passed me though but them again 350bhp M3 against my little Polo I expected it a lot sooner. Still I did do him off the lights at the start which amazed me as that was the first full power standing start I have ever done with a paddle clutch fitted, and on those tyres.
Top 12 qualifiers were out of 33
Jaguar XJS V12 1:19.596
VW Corrado V6 1:20.313
Mazda RX7 Turbo 1:20.320
Rover 220 Turbo 1:21.232
Rover 220 Turbo 1:21.417
BMW M3 E30 1:21.922
BMW M3 E30 1:22.302
VW Polo G40 1:22.619
BMW M3 E36 1:23.461
BMW 320i E30 1:24.748
Ford Capri GXL 1:24.781
Race result and best times top 12
1st Ken Lark VW Corrado VR6 1:21.065
2nd Robert Payne BMW M3 E30 1:20.771
3rd Brian Stevens Jaguar XJS V12 1:21.616
4th Anthony Gorman BMW M3 E36 1:21.687
5th Graham Meeks Rover 220 turbo 1:20.941
6th John Willcocks BMW M3 E30 1:21.113
7th Anthony Wright Rover 220 Turbo 1:21.600
8th ME VW Polo G40 1:21.662
9th Ian Clark Ford Capri GXL 1:24.300
10th Michael Daly BMW 320 E30 1:25.211
11th Liam Crilly BMW 318i E30 1:2..412
12th Andrew Partridge BMW 320i E30 1:23.920
All the times seem pretty close which is really good. Just a little improvement in line from one driver would prob. see the order change quite significantly. Certainly looked close on film and that's the best for entertainment.
2 things.
whats the spec diffence between the cup and a normall G?
and why was that guys wiper up the whole way ?? that would fuck me off a treat
