ENGINE BAY DEGREASING / CLEANING
anyone got any tips on cleaning engine bays ready for painting...?
I'm using gunk at the mo and seems to take an eternity to clean the smallest area....
is there a easier method or do i just need to persist with the hours of agonising elbow grease!!!!! HELP!?
  • Replies 8
  • Views 1.6k
use elbow grease from focus diy
get some Rock oil SOC (souible oil cleaner)
works mint and you don't need a lot
cool!
what place sell it do you know as I've never heard of it.....? cheers.
Use brake cleaner! Stuff works a treat!!
It does take alot of work cleaning a engine bay . Iff your painting can you not sand the paintwork off with some paper then filler the bay to smooth it a little then smooth angain with some lighter grit then get started with the painting ??
well the bay is in pretty good shape, and will only need touching up in places like where brackets & holes have been welded up.... but at the mo it has major gunk in places and find I'm going trough loads of brushes & cloths etc as after a while they stop cleaning an just push the crap around.....
plus you can hardly rub a surface back with crap all over it..... pissing into the wind with that one i feel!
True mate true . Yor bay must be rather dirty . I managed to get majority of the grime off the inside of my old car wityh a sponge and water with a shampoo and vinegar in it .. I then used a bit of TCut and polished the rest . I diddnt take the engine out unfortinatly wish i could of but it was my daily . Just removed everything i could remove fairly easily and had a good old spring clean . Good luck with the cleaning . Its always nice to see a immaculate engine bay !
yeah to say its got some crap in there is an understatement! around the chasis legs you can peel it off! its kinda like waxoyl consistency! plus oil from where the old engine leaked above the alternator has managed to get into every crevace known to man! underneath the paint is great though, so there is some motivation there but god dam its boring work!
dont suppose anyone has removed the firewall, as was thinking about doing it to completely flush everything but am wondering about the implications of moving the servo lower down...... if there is any?
