Clunking noise when turning steering???
I've jus fitted a spring and shock kit and when i turn the steering wheel left or right there is a clunking noise coming from the front.
why does this happen after lowering car???
  • Replies 20
  • Views 3.8k
When your stationary or when your moving? Or both?
it happens both
anyone who can help??
thats your wish bone bush i had it just check them !! does it make the noice when you turn one way or both?
makes it both ways
is it expensive to do
makes it both ways
depends on if its both bushs or the one get it checked out first tho
why does it happen after lowering the car
mine didnt knock when i slamed mine its wear on the bushes so when you lower it it wears twice as fast
oryt. will there be problems if they arnt not changed??
also how much will it cost about??
well i paid around 100 quid but that was for a few other things as well your first job is to check that the bolt holding the bush in is nice and tight if its loose nipe it up and see if you have the problem. then you can also check your drive shaft and your steering arm for damage mk4s have been know to have wear in them werth a check before you take it in !!
does it make the noise when u move i now when kidd lowerd is car he got that clunk when he was driving ?
That could be the ARB though ^ If it was a 16v
  • 5 months later...
the clunking is back after some time
could it be my ARB??
My clunking noise happens on my top late which sits on the springs. It has slipped a coil
Check this aswell
^ My front offside spring has cracked and slipped off the mount which causes a clunking. Saying that its stopped for the time been
One of my springs had also slipped just after fitting. Refitted and no more clunking.
Mine dont do that. Refitted it 3 times but keeps slipping but it doesn't help that I am using a standard top plate :(
Mine slipped a couple of times. Bought new standard top plate and seemed to fix it. Was on FK website earlier and noticed they sold bigger top plates.
Thats the one!
