HELP - can't get screw undone!
I don't know what i was thinking when i did the screw up but now i can't get the screw undone in the drivers side window winder! Its so tight that its starting to shag the top up so the screwdriver won't grip!
Anyone got any good ideas how to get it out? Need the winder in one piece.
Jon.
  • Views 1.4k
Drill it out.
what he said ^^
If thats the easiest option then so be it!
Used an impact drive on mine
If u drill it then make sure you keep it cool!!! otherwise the heat generated by the friction will melt the surrounding plastic!!!! :-D (BIG MESS)
drilling the top off the screw will un-torque the rest of the thread and it can then be twisted out by hand. Make sure it doesnt get too hot as said above.
When i f**ked the head on a bolt for my go-kart i got a star drive (thing with the * head i don’t know what it is really called could be a hex drive :? ) and hammered it into the screw so it cut a new head and carefully unscrewed it
Edited by BigAl.MK4
