bumber strips
do u think mk 4 would look better with strip off and if yes how are ther held in glue or like rivets
  • Replies 22
  • Views 2.7k
They're glued on. Hot water, hairdryer, patience, bug & tar remover, petrol on a rag, soon removed. It's a popular mod.
So mine are still there. :lol:
are cool thanks so not going ot have hole in the doors if take it of flike u see people in like there 206 with hole sin the side of there car u might aswell left it on. erm yes eill most likly take them off it a blue car so the big black strips look funny lol ?
No, there are no holes.
I like the black strips on blue...
slide a credit card in between the strips and your car then just slide it all the way down they come straight off then just get abit of petrol or white spirits and just rub the glue off :thumbsup:
bumber clart
bumber clart
ye si tink i wil try that is there anything apart from white sprit or petrol is there anythink else u can use ?
Hairdryer to get the corner off. Rip it all off slowly then scrub the foobar out of it with a damp cloth using methanol spirit. Comes straight off and always a must mod on any mk4 thats not black!
I TOOK THEM OFF THAT WENT FINE BUT WHITE SPRIT ON IT TO GET THE GLUE OF BUT IT WONT COME OFF WAHT COULD I USE
dont need to shout mate.
try t-cut worked for me
white spirit worked for me. Just took a very long time. you gotta have patience mate.
I would seriously not do as above, unless you keep it COMPLETELY dust grit free you will pick up say a tiny bit and then scratch down your bodywork...
how come
because dust scratches paintwork! bug and tar remover worked for me mate
yes done that its coming off slowly , i think its just gunna take time , the only other thing is that the back left hand door paint has gone lighter
I found the best thing for getting the glue off is Carb Cleaner. Get it from Halfords in a spray can. Soak the glue leave it for 5 minutes, spray it again and then rub it off. It just killed the glue on mine and came off really easily.
I think WD40 worked as well carn't remember but use the Carb Cleaner
I used WD
White spritis worked for me but i was using a broken ruler as a scraper.
Edited by scrobert
is it the same method on a 6n2?
nope they have pins holding them in so require welding upand spraying, but if you used the search function you woudl find out alot more!
sorry to hi-jack
but is this the same for mk3?
Edited by low n slow
i dont know but did my mk4 got the glue off painted where the lighter paint was andl ooks good now
