centre consol please how to remove????
hi could someone please post how to remove the centre consol the pastic bit around the radio and heter control knobs without breaking it it lookes asif it is just cliped in but would like to know as I've seen one in the scrap yard bt dnt what to break it taking it out.
also can someone also put a step by step guide of how to remove the speedo and the gear knob as i want to put lockwood dias in and a neew gear knob but i lack in experence and have a little temper haha so dnt want to break anythng.
thanks .mark.
one other thing i was thinking of having my stantard 16v alloys sprayed black but was thinking if i have the centre caps sprayed black will i cip the paint everytime i need to take the centre caps off to take the wheel off? if anyone has done this and has any feed abck ony any of this that would be great.
cheers once again.
  • Views 1.6k
bump
not 100% sure but i think its is a fairly big job as you have to remove alot of the surrounding things on the dash to get to some of the bolts, it tells you everything in haynes though.
pull the gaiter off from around the centre console and pull it up and youw ill see a shiny ring around the bottom of the knob with a slit in it get a flat head driver and pry the ring apart until its loose and the knob pulls streight up.
cheers once again.
if you are careful and do it slowly i cant see why it would chip, you wont need to remove the wheels on a regular basis so i cant see it being that biga problem
cheers for the reply ill have to get a haynes manual but i haven't beeen able to find one for my enigne its the 1.4 16v but supose the rest of the car should be the same as the others so will have to buy one.
thanks once again.
yeah I've nots een one for a valver mate I've looked myself, but for this i can see it being a great helpa dn its always there if you evern need a quick answer in the future. best of luck :D
if its the 6n your talking about theres a few screws by the heater dials, and two at the back of the little tray at the bottom, you gotta take the heater dials off aswell i think.
as far as i remember anyway, if it dont come off easy i wouldnt keep pulling
