G40 engine'd rollling road graphs
I thought it would be a good idea to have one place to post everyones RR graphs and list the mods so people can see what works well with the G40 engine. Hopefully this will stop all the "I've fitted furry dice, how much power does that give me now" threads lol
Please list the following,
Induction> Air filter type, manifold used, throttle body used, any porting carried out
Type of forced induction> G40, G60, Eaton, turbo etc
Pulley> Size and type
Cylindor head> Standard, ported and polished, Big valve etc
Camshaft> standard or make and duration
Exhaust Manifold> Standard or 4 branch (which make?)
Exhaust system> Size and make
Fuelling> ECU used, injectors used, chip used
Headgasket> Standard or metal
Pistons> Standard cast 1272cc, 1341cc forged etc
Rods> standard??
Crank> Standard??
Flywheel> Standard or lightened
Edited by LregG
  • Replies 8
  • Views 2.4k
Anyone??
Everyone is just interested in "phant stance" and "mad dish FTW!!11!"...?
My blue G40 a couple of years ago, now standard again.
Induction> Large induction K&N cone air filter, GT inlet manifold, de wedged stock throttle body.
Type of forced induction> G40 Full blend
Intercooler> Standard.
Pulley> 65mm Toothed pulley kit.
Exhaust system> Stock decat downpipe and mid section. Custom stainless backbox.
Fuelling> Stock ECU and injectors with Poloace chip.
Rods> standard
Crank> Standard
Flywheel> Standard
This was a tight 32k miles engine, so not much loss through transmission etc.
Cheers nick, lovely torque curve that set up had
This was in my old "LregG" that luke (ahh claudia) now owns, the engine lives on in the beige beast which i still own
Induction> Large induction K&N cone air filter, port matched GT inlet manifold, 51mm throttle body.
Type of forced induction> Eaton
Intercooler> AW tracksport
Pulley> Toothed pulley kit
Camshaft> Standard
Exhaust system> Stock decat downpipe and 63mm bastuck system, single silencer
Fuelling> Stock ECU, green injectors and a PSD remap with an sns stage V base code
Rods> standard
Crank> Standard
Flywheel> Lightened
189bhp and 162lb/ft of torque which was not bad considering the amount of standard parts still on the car
Edited by LregG
Two examples which demonstrate the differing torque/power of the Eaton vs. G40 induction...much more progressive on the Eaton...big LUMP in the G40!
That is right tav, the G40 torque comes in hard and low and tails off early whereas the eaton is more progressive and it holds on until high up the rev range before it starts to drop off alot. Due to this the eaton was easier to pull away in without massive amounts of torque/wheelspin
Induction> Jetex cone filter, Jabba cold air box, dewedged TB, standard intercooler + chargecooler, GT inlet manifold
Type of forced induction> G40 R1
Pulley> 65mm toothies
Camshaft> standard
Exhaust Manifold> 4 branch PSD
Exhaust system> 63mm bastuck, twin silencer
Fuelling> PSD chip not a custom map, standard injectors
Rods> standard
Crank> Standard
Flywheel> Standard
i cant find my print out from 06 but without the toothies, 4 branch and GT inlet, but running a 65mm pulley it made 144bhp
this year i was hoping for more like 175+ with the addition of green injectors, vernier pulley, shrick 252/276 cam, custom PSD remap and a fresh charger
