colour coding front splitter
has any one tried colour codeing their front splitter themsleves?? also what paint is best to use??
  • Views 740
I did it. I used rattle can from VW
how did you spray the splitter?? just remove it and spray it as is, or did you rub it down? cheers
I rubbed it down with fine grit. The I sprayed it with 2 coats of primer, then 2 coats of paint. Finished with a coat of laquer. You could do more coats but mine has been fine for months with no chips/ marks.
