seam sealant removal....how to?
I've gotta remove the seam sealant round the front turretts as am removing the fire wall and smoothing the bay, but just wondering if anyone has any tips for removing the sealant....... ?
i would hazzard a guess at heating it up etc....?
  • Replies 9
  • Views 1.8k
Nope!
You need to grab your faithful angle grinder and get a knotted wire wheel (about £6 from Machine Mart). Clean it all up like that.
Once you've done that you need a spot weld drill bit to remove the scuttle tray. I found it easiest to work out were the spot welds were. Then cut it out with angle grinder then drill out the spot welds. With the bits being smaller its easier to work with. I found anyway!
Heat and a scraper.
naa dont bother with a scraper and that i would just do what kanaspam said. to get the location of the spot welds i ran the wire cup brush along the edge of the panlel your removing so you can see the bare metal then you will see the indents and they can easily be drilled :D
Edited by POLOMON
good bit of advice boys! :)
will crack on with it hopefully with good results!
been told the sealant is flammable if you get it hot enough 8-)
Nope!
is it a 6mm spot weld drill bit i need...? its either thator 8m i think
Nope!
i woudl get the 8 as its always better being too big than too small (:paranoid:)
good point!
