DIY Guide - Rear light tinting
First of all I would like to point out that this is a DIY guide for the interest and use of others, I therefore cannot be held liable or responsible for any injuries/damage caused while attempting to replicate anything shown.
Always take the necessary safety precautions and use basic common sense, unless you are sure about what your doing leave it well alone! And also have fun at the same time!
I guess this can be done on any rear lights, this guide is shown for a 6n. I decided to do this because Mk5 rear lights have been done to death and also this is much simpler, cheaper and in my opinion better looking.
Needed tools and equipment - 10mm spanner, masking tape, newspaper or something similar ( I used a cut-up bin bag), craft knife and of course proper tinting spray!
I chose red, black is too chav for my liking and red blends in well. Shop around for spray, Halfrauds charge £15 bloody quid for a 250ml can! So visited my local autoparts and got a 500ml can for £12 and didn't really use that much.
Here goes!
Step 1 - Open the boot and pull back the carpet, push the two clips holding the light cluster in and gently pull it out,
I disconnected the cluster to make it easier to reach the bolts.
Spanner ready, undo the 3 nuts taking care not to drop them down the arch because you won't get them back!
Pull the light out, mine took a bit of persuading nothing that a bit of vigorous tapping can't solve.
While I had the light out I took the chance to clean all around the paintwork with some warm water and a cloth.
Step 2 - Now for the prepping, as they say, prepping make the difference between a bodge and a quality job.
After thoroughly cleaning the light give the areas you want to paint a quick keying, I used a dish scourer just to take the shine off so the paint adheres better.
Now to make sure there isn't any grease on there give it a quick wipe with white spirit or something similar, myself I used a bit of vodka lmao!
Step 3 - Now to tape up those areas you don't want sprayed, as you can see from the pic's I only wanted the indicators and reverse light sprayed so that it blended in nicely.
Then using a craft knife to trim the masking tape, I simply followed the moulding lines on the light.
Step 4 - And now for the spraying, I did several very light coats so that the paint wouldn't run. Be careful not to overdo it, otherwise your indicator's will flash red resulting in unhappy plod and MOT testers!
Best way I found was to hold it at a distance and sweep side to side.
Step 5 - When your happy with the results take the tape off, bolt it back in and the jobs a good 'un.
Here's the finished result, i'm very happy with the result, nice and subtle \/ \/ \/
Hope you like, any comments welcome! Matt
Edited by notoriousmagik
  • Views 890
Popular Days
clear laquer applied afterwards, increases the shine and also seems to stop red from fading so quickly. also if you use something like a palm sander to key the orange bits, you will find the lense goes almost opaque, so you need even less tint spray. one final tip, always sand off and raised markings or writing, otherwise it will look pikey
