bumber f-ing strips
i took my buber strips off the other day and that stupid glue stuff was on there and well i tried what people said i treid white sprit , tar remover and meaths and it wont go also i took all them off and when the last one came off the back left door i saw that the paint was lighter has this happend to anyone help please
  • Replies 10
  • Views 1.7k
sticky stuff remover from halfords!!!!!!!!!!
best stuff i ever bought works a treat.
and buff up the paint?
took me about 3hours to get rid of it all, credit card - sticky stuff remover - patience.
get a hair dryer on the job maybe another idea as i used this when taking them off... your only left with so much glue as you likely pulled off the strips too fast seperating it from the glue making your current job harder.
dont worried I've been there!
doing it on my mk3 this weekend.
wish me luck :paranoid:
go into a motor factor and ask for a ''caramac wheel'' its a orange rubberd disk you put in a drill ( kind of like those wire brush doo-daas ) give it a blast with tht n it'll be no bother.. eg. i took the side mouldings and badges off my mk3 and got all the sticky stuff off in less thn 15 mins..
cheers for the help just going to take alot of time lol will carry on ever day doing it lol so what that stuff from halfords works does it ? might try hair dry to to heat it up , yes i dot no whats up with the lighter paint, i thgink might see how much a re-spray would be on that lil bit , its just so anoying it take for ever should of really taken them of slower so my fault really
took me 3mins 2 get em off, but like 3hrs to rub the clue off, just srub really hard lol
what did u use to scrub and did u use white sptie or anythign
Give your mouldings a heat up with a hairdryer or hot air gun, then SLOWLY pull the moulding off.
If you do it like this you shouldnt get left with much of the double sided tape.
If you have any tape left on the body forget the quick options of caramac wheels and solvents, all you'll do is soften the paint with solvents or maybe burn it with the caramac wheel.
Using your thumb start at the end of the leftover double sided tape and just rub it, it will come off but takes a while and you'll have a sore thumb at the end of it.
I have to do this almost every day for my job and this is the easiest way without damaging your paintwork.
Petrol does it nicely.
Dont leave it on there though or the paint will go soft.
