Removing the front lower panel on an MK2 polo
Hullo!
Just quick question. I've looked in my haynes but it doesnt cover this. My MK2 'loon has had a knock up front in the past and the front lower panel (the one under the grill that the bumper bolts to) has been pushed in a little and the paint has cracked and started to rust in one spot.
Now the question is, how do I remove this panel?
Is it welded atall or just bolted in like an MK2 golf? any glue etc? Also would anyone be able to tell me where all of the bolts are. As said, I have a haynes but it isnt covered so the likely hood is that ill be hunting around for bolts which you cant see :-p
Any help greatly appreciated! Thanks
  • Views 1.6k
It's welded on iirc.
mawww :cry:
Can anyone confirm?
Yep, welded on. Something I'm replacing on my F plater at the moment, but not because it needed it ;)
^^^i no what your doing :grin:
yep defo welded done it myself before
luke
is it a hard job to do? or what sort of price would i be looking at for a bodyshop to do it?
its not difficult to do if you can weld.Just a case of drilling out spot welds then drilling holes in the new panel fit and realine then plug weld the holes grind the welds of prep and paint
luke
