Top end KICKER amp
Well... lol I've got my kicker for sale.... I never thought i'd do it but my clutch is on its way out so moneys are needed.... I've copy and pasted all the details from the Kicker Uk site and manuals....
Amp Specifications
Amplifier Type: 2-channel
RMS Power @ 2 Ohms: 200W x 2
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 400W x 1
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >100 dB
Every once in a while something comes along so radical, so out there, that everything that came before it just seems "regular." The new Kicker SX series amplifiers with 32-bit digital signal processing blast car stereo to a whole new level of power and control. Forget about knobs and switches, and forget about limits. The Kicker SX gives you total control and tons of legendary Kicker power.
Built-In 32-Bit Digital Signal Processor (DSP)
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 16kHz variable high-pass frequency adjustable in 1/12th octave steps
30Hz – 20kHz variable low-pass frequency adjustable in 1/12th octave steps
6 – 36dB / octave variable crossover slopes
Digital KickEQ fully parametric equalizer
20Hz – 20kHz variable frequency adjustable in 1/12th octave steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable left / right independent phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display
The flexibility and precision of DSP is just the beginning. The SX series is all about pure, clean, audiophile power, with handpicked tight-tolerance components and a no-holds-barred design philosophy.
Features
Audiophile components throughout
Double-sided glass epoxy circuit boards with large copper traces
Oversized Litz wound toroidal transformers for improved efficiency
Large TO-218 bipolar output devices for higher current capacity and reduced resistance
Triple Darlington output device configuration for lower distortion and excellent sound quality
Custom-wrapped HFQ electrolytic capacitors for maximum bass impact
Precision tolerance metal film resistors and poly film capacitors in the audio signal path
Isolated dual power supplies
Fan cooled
Remote level control
Custom-tooled oversized power and speaker output terminals
PreAmp Signal Transfer (PAST) output RCA lack
Soft muting circuit controlled by the DSP
Soft start turn-on circuit for deduced startup load
Removable cast aluminium EndKaps
http://www.kicker.uk.com/sxamps.html
There all RMS figures btw and underrated.... It comes in box with manuals n bass controler... More details and specs available here... if you have any more q's send a pm..
http://caraudiosecurity.com/shop/product/p...ts_id/3314.html
Asking 190 ono.....
Collection only... i wouldnt even bother considering delivery so please dont ask! Its a high end amp... not taking the risk!
Also can be heard working as its in my uncles car at the mo! lol or if your cars wired up your more than welcome to try it out!
Can get pics if needed... its in perfect condition though!
Abdul
Edited by big_k
  • Views 450
Bump need the money so 175 fixed!
where in london would u take 150 for it
pm me please
pm me please
You have pm 8-)
BUMP..... 175 ono!!
BTT... make an offer!
Jeez its difficult to sell things these days!!! 140
Bump..........
