Anyone ever built a dolly for their Polo?
I fancy doing this for mine so its not just sat in one place on axle stands. I don't mean the kind where you can tilt the car around and all fancy stuff. Just something simple so its effectively on wheels and can be shifted about but doesn't need the suspension on so you can work under it and stuff.
  • Replies 10
  • Views 1.8k
find some heavy duty castors and bolt them to a peice of wood.
if there is no engine int he car its surprisingly light
At the moment it just has a rear axle, rear suspension and wheels. So I can move it about on my own at the min. But its just not as maneuverable as it would be with proper 360 degree moving wheels, like on a trolley!
4 bread tollys from a asda store near u! :ninja:
then some wood :nod:
I'm planning on using bread crate trolleys from work for the mini, I've stole 3 just need another 2 now (want 1 to put the engine on too). Not sure if they'd be strong enough for a polo though, the wheels would break if u hit a bump under the weight i would have thought. A bare mini shell is light as a feather so I'm hoping they are going to be strong enough for it.
the wheels will hold up...but my mate took them off the bread basket
and attached them to a blue pallet which is bigger and stronger ;)
Get some heavy duty castors, from screwfix or similar
And get a pallet, from a builders merchant, I'm sure they would give you one if you ask nicely.
i have a bread trolley i robbed from chelsea fc! its more than strong enough for an engine and i would be confident puttin a shell minus engine on if i had two, just make sumat to join them together and then attach some wood to sit the car on.
i cut two old folding seats up and ziptied the pads to mine and now use it as a bit of a wheely stool come creeper! is reet!
lol!
surly that would be some kind of jig there pritty easy to fabricate
