Is it worth it???
Is it worth sorting out my valver or should i just sell it. I have had it 6 months and bought it for £1000. when i got it i took it to VW for a service and a pre MOT. they did about £700 work on it for me, but they also gave me a list of recommendations that need to be sorted out such as timing belt, sump and other various bits n bobs i have also taken care of the usual rust spots on the car e.g. on whell arches etc. so should i do the work or is it not worth it. Help
  • Views 946
Whats wrong with your sump? If it is just a leaky gasket then that shouldn;t be too much hassel.
Timing belt has to be done on all cars at certain age.
I'd weigh up the cost of fixing the car to selling up and buying a new car, but then you might have to spend out again on big service parts on the new car.
i wouldnt risk not doing the timing belt. where abouts in oxfordshire are you? I've a few mates who are mechanics and could do the belt on the cheap for you
i am just outside banbury
Voodoo Motorsport is in Aylesbury
give Elie a call and see if they can help you
id spend the money on the car as, unless you are selling the car dirt cheap, most people will be put off by a car that needs work like that doing
