Hello!
Hello All
My names Tom, i work in parts at Heathrow Volkswagen in Ashford, Middlx
I've jonied up to your forum because we have just entered a VW Dealership competition called Dubmasters 2008. This competition is for all south-west VW dealers in the UK.
We basically have to build a VW Track vehicle using a budget of £1500 and put the car through its paces at GTI International At Bruntingthorpe on June 21st against the other Cars from the other Dealerships! the areas are tested on 1/4 mile, Top Speed, BHP, Handling, a 'pit stop' challenge and a Concours section
We Have Aquired a Polo G40 on a J Reg For £1300. It already had some mods including
Schrik Cam
FSE power Boost valve
K&N induction Filter
Jabba Sport Supercharger Performance Upgrade (Stage 4) with a 68mm pulley
Jabbasport Sport Chip
De-Cat pipe
Mongoose Exhaust System
Koni Uprated Suspension with Eibach Springs
Uprated Brakes with 22.2mm Master Cylinder
poly bushed
Dnyo printouts say 137bhp 135 lb/ft with a power to weight of 165bhp/ton
what i ask of you polo guru's is advice on what mods to make with best improvements with little spent, as it goes we only have £200 left of our 'offical' budget, though selling parts ie interior etc has not been mentioned about where that money could go ;)
Any advice/help is much appricated, id also like to ask questions so hopefully keep this thread going as long as possible! :lol:
Thanks in advance
Tom Page
Parts Advisor
Heathrow Volkswagen
Tel - 01784 258877
Fax - 01784 253414
parts@heathrow.volkswagen.co.uk
Edited by Tom@HeathrowVW
  • Replies 111
  • Views 8.4k
coolest dealership ever!
£1300 for a modded G40 is a bargain though, but i cant answer any questions regarding them as i dont know enough about them :-D :lol:
Wow that sounds cool.
Theres loads of G owners on here so you've come to the right place :thumbsup:
Thanks for the posts guys!
I've always been a forum user, and know a loy of knowledge can come from them.. i just hope the other competing dealerships dont think of my sly tactics :lol:
heres a quick one...
if you pull the throttle body off and look inside there are 2 "wedges" that restrict airflow... these unscrew and u can fill the screw holes with bolts or a rivet gun....
also if you fit a "GT"(mk3 polo) inlet manifold and port the throttle body to match this also allows better airflow....
theres a start for you... you may find both of which have already been done... check the part number on the inlet manifod if it ends in D then it is still a standard G40 inlet but u want one ending in B....sure u have access to all the part numbers anyway!
and only way to check the throttle body is whip it off and have a look!!!
You'll get other people with names similar to yours signing up askign the same questions :ninja::lol:
G40 was clearly the best option as they are lightweight and very quick with a few cheeky mods.
As you say stripping the interior to a minimum would help with the drag race and speed etc, I'm not sure if that would be marked down on the concours bit?
There is always the option of getting a 65mm pulley, which i reckon could be got for relatively cheap.. If you choose you can go even smaller than this.. Benefit is much boost but not for long haha.
I'll state the obvious but weightloss would help. Strip it internally. Roof lining, carpet, everything. Take the metal inserts out of the bumpers, every scrap you can shave off = more bhp/t
Also fit a brace bar just infront of the arb mounts like this pic.
Nice one, i found out about the de-wedging online a bit earlier, seems like a good one to do, and ill check the manifold 8-) I'm about to start some work on the car tonight with a few of the technicians, so overnight ill check the Throttle body and check. Ill keep you guys all updated of our progress as we go, and if any of you are at GTI festival make sure you all come say hi!
ill also try and provide photos of progress,
also a little advance warning, after the competition this car will be auctioned off by the creators of the competition, and as far as I'm aware its anything over £1500, anything over this amount goes to charity :-D
Tom Page
Heathrow Volkswagen
wicked throw sum pics on here if get a chance mate!!!
i'd of thought a mk2 golf 16v would of been a better option, they can be picked up for less than a G40 leaving more cash to tune it up, they come with 150bhp as standard (iirc), and would easily out handle a mk3 polo.
your always gonna struggle to get a mk3 polo to handle well for little money, especially compared to a mk2 golf which i'm guessing most of the other dealerships would of opted for.
but saying that it does sound like you got a good deal on the G40, good luck with it, i'll probably be hitting inters this year again so i wil keep an eye out for this :thumbsup:
You could stick a smaller pulley on the charger, the chip would prob be ok with it, and run it on BP 103 may help give it a little more on the day.
Our Car we intended to use was a V5, as we had it already, wasnt the best option, but the reason a G40 was chosen was a friend of mine wo regurally buys parts offered it to us at a reasonable price. hence the g40 8-) it was a limited choice, but a good one :lol:
Wait Wait, so if you already had a car it count's as free?
So one dealership my turn up in an R32?
Edited by deajam
this could get intersting haha pull a turbo off a 20vt that uve got on the forecourt... bodge up a mani n you are laffin lol!
cant believe you are mate would sacrifice his G to get it stripped n what not... i'd never let that happen to mine!
Deajam,
The car has to be brought with the budget, as after the show the car is auctioned off, so If a dealership turned up with one of their sales vehicles they would loose out big time! The V5 was a customers car that had too interior damage and wasnt cost effective to them,so they decided to get rid of the vehicle by giving us the log book ;)
G40 AD
Luckily for the old owner, this was his 2nd G40, he never used it and is in the process of buying a gold G60 fire and ice ;)
so moving this G40 off his hands was a good deal for him ;)
Tom
Heathrow Volkswagen
This sounds cool .
Would of been better with a cheapo mk2 Golf though .. 8v to be honest there tuned easier .
The G will be quick though and is diffrent its not the straight forward choice is it .
Iff only they were cheaper to buy then you could of chucked a turbo on it .. 200+Bhp . Mmm
fair play he's a lucky guy 2G's!! i want a second to play with so can keep this one oe!
If you're putting on a brace bar as mentioned above, you may also want to see if some ARB blocks are within your budget too, as I understand this will also help with the handling.
Well, that's what the mk3 owners around here say - I haven't a farking clue. :lol:
not a g owner but howz about a good set of tyres??
This sounds very intereting good luck with it
tires are an issue, we found that on the 13's it was a bit scatty, though the tires on it right now have less rubber than an elastic band, and the elastic in the band would be of a better quality right now!
Though i have been chatting to Andrew Strange via email, and Yokohama A539 are a good choice
I must say i only joined up this lunchtime and already I've bee bombarded with real helpful friendly advice 8-)
You guys really know how to make a new member feel welcome!
Tom Page
Heathrow Volkswagen
Tom Page
Heathrow Volkswagen
lol.. friendly bunch on here!! sure ull get alot more advice on this later.
just remember you camera tonite.. wanna see www.clubpolo.co.uk on it somewhere!!
keep us updated. ;)
yeh that seems to be what new member generally think :lol:
good luck anyway, sounds reet fun!
Tom Page
Heathrow Volkswagen
keep us updated. ;)
As soon as Andrew sends over some stickers ill get them on and some pics up :)
