Hello!
If you can't think of anything to spend that £200 I'd seriously consider getting it properly mapped rather than just a generic Jabbasport chip.
I personally think you should be running a bit more than 137 bhp from that spec.
Do you have any idea when the charger was last serviced, and do you have a boost gauge?
  • Replies 111
  • Views 8.4k
a539's are SHIT HOT!!!! lovin mine got 185 50 14'son a 14x6j............... lovin them! had a021r's on before on a 185 60 13..WANK!!! racing spec tyre wate of time n money!!!
this sound proper cool
I've no experience with G's but it might be worth speaking Alan who runs the fahrvergnugen tuning on here, he does generic chips, and made a big diff on my 1.4 16v when i was using that
Models: G40 Coupe & Hatchback
Engine code: PY
Description: 1272cc, Multi-point injection, Supercharged
ECU No: 030 906 022 C, (suitable for other variations)
Performance: 5-8bhp and 10Nm torque
Eprom: 28pin DIP 27c256
Notes: DIY installed in less than 30min, Soldering may be required on late 93/94 cars
Price: £30+£1 P&P including fitting instructions & storage box
EXTRAS: Free raised rev limiter stock, 7300rpm or 8000rpm, 65mm Smaller pulleys are available for £60
stick a couple of new V belts on the charger and make sure they are real tight.. didnt notice if you said it was decatted.
if you want a 65mm pulley i have one here if you want it - 20 quid?
If you’re going to change tires I would use Toyo R888, slick compound that is road legal superb tire. If you contact Alan Meaker at Toyo I’m sure they would help with a set.
65mm pulley - £20
Poloace chip - £30
(need to get a chip to suit the 65mm pulley)
If its running right, that should see it past 150bhp. Mine made that without the cam, decat and exhaust...
Front brace bar for infront of the anti roll bar. - £10/20?
Sell the interior off, and get it on some decent tyres if its not already. Give it a service.
That'll be your most effective start IMO...
Good luck, sounds like fun!
Thanks for all the comments so far! 8-)
Spent Friday night late at work, took out the whole interior in one piece, except the dash, as we decided to keep that in. So I'm gonna do some digging and find out what sort of money they go for, its in real good condition.
Definately sounds worthwile going for the 65mm pulley, and I'm yet to check the belts etc, but ill do that during the week
as i am not directly in control of the budget :cry: ill have to get the go ahead from the boss, who is loving this project already, there was a lot of tence moments at a meeting the other day when they found out heathrow had some tricks up their sleeves ;)
I'm not totally sure of the last service etc, though it has a full VW service history and original paperwork from when it was 1st purchased, got a lot of history with it. ll work over the engine this week 8-) . Also the last power graph we have was in 1999, powers could of increased since then, my idea is to try and blag a rolling road session somewhere in exchange for a bit of free publicity ;)
I also noticed that its not a full system on the car, yet it is de-catted, so a new system might help out a bit i think :)
Just got a pic of the engine bay so far, give you guys a better idea of what er dealing with :)
Tom Page
Heathrow Volkswagen
is Alan Day of New Southgate taking part? If so I can find out what they have in the pipeline for you.
Tom, was you the matey in parts today when i came to get a carb spring for a mk2 golf? I came there in my g40 today. I know quite abit about g40s mate, if you guys need any help just pm me as i only live down the road by the vauxhall dealer. Also, does dan still work there?
Matt
Matt
No that would of been Chris... hes our trainee,
:lol: plus I'm better looking :lol: to the blind anyway... :lol:
If you mean Dan with the mk2 VR6, then yes hes still here, like part of the woodwork in the workshop!
pop down and say hi, I'm in all week and on next Saturday morning
Tom
Edited by Tom@HeathrowVW
Cool, will do that, what time are you lot there till in the evenings?
I used to work with dan at john ashley motors before it got closed. Do you know if there are any job vacancies going at the mo for a techy? :thumbsup:
there was a job, it got filled on Friday, though when you drop in, bring a CV with you, they could be some more coming up
We're there Monday to Friday 8:30 - 5:30 and Saturday 9:00 - 1:00, I'm in this Saturday, myself anc Chris Alternate each weekend>
Tom
Will do, i'll pop down on saturday as i don't finish work until 6 during the week.
not too sure on that, but ill try and find out the competitiors on monday and see :)
Tom
If you can get a larger bore inlet manifold from a Polo GT that might be a good shout when combined with the 65mm pulley and a chip. It would give a little less low down torque (not a bad thing on a G40 as it's got a bit too much as it is) and more top end bhp. These sell for about £50 on here...but you could prob. get one from a breakers for a tenner.
Might start reaching the limit of the stock injectors though, as the air flow will be much greater towards the higher end of the RPM range...which would mean getting a set of Corrado G60 items which aren't cheap...again unless you could get them from a breakers or something. You'd then need a chip to suit all the mods: ported charger, 65mm pulley, G60 injectors and anything else that has upped the air flow. Perhaps stopping at the generic chip + 65mm pulley will see you good.
If you've been emailing Andy then you've probably got lots of good information at hand by now.
get some v belt spray too, its very cheap, bout £5. i use it on my g40 as i dont like having the belts too tight. without it my belts slip at 5500 rpm, with it they dont slip till 6500, a place my g very rarely goes anyway! it pulls slightly better too
I meant to look at the manifold on Friday night, but i didnt get a chance, a i think that might of been done already. defo think the 65mm pulley will be used, i might of come trumps on the Rolling Road so thst should point us more in the right direction :)
G60 injectors sould like an idea? ill check the cost at work and see if i can write a set off :lol:
Seems like a really cool idea. Hope all goes well
I wouldn't bother with the G60 injectors unless you are planning on a suited chip. As said, traction will be your biggest aid. Price up a pair of 185/60/13 Toyo R888's or 175/60/13 Yoko Advan A048's at trade discount. I think 150-160bhp should be a good power for you, this would easily give you the edge on any Golf or Corrado 16v's taking part. Even stock VR6's will not stand much chance. If another dealership finds a cheap Corrado G60 then it could get interesting!
A048's are about £75 retail?
Nick's good to point out the G60 injectors really need a chip to suit.
Standard G40 is good for 7.4 0-60 and 0-100 in about 22seconds...4+ seconds quicker than a stock Corrado G60...you should be in with a good shout running 150bhp, achievable on standard injectors like PhilJ's spec. earlier.
Edited by Tav
Shame you haven't got a toothbelt kit lying around somewhere lol that would stop all your slipping an help you get all the power down most G40s have gone this way unfortunately its just out your budget mate.
Good luck with the project sounds like it will be fun.
I've seen them at £67 retail each for 175/60/13
Belt dressing will be more cost effective than toothed pullies for a run down the strip.
cool 8-) ok ill leave the G60 injectors off :-D
hopefully if we can arrange the rolling road we can gather some info and decide which way to go from there,
I've heard rumours of another G40, a corrado VR6 and a mk4 2.0 gti, bot many other dealers are being quite quiet, so our brand manager tells me 8-)
Hopefully most dont have a experienced rally driver in their workshop, and a race driver in the parts dept ;)
MK4 Golf GTI 2.0, pah there are like 113bhp standard :badgrin: And a Corrado VR6 for £1500???? They must have robbed a granny on a part ex deal!
Just had a thought, do these cars need to have MOT's? If not then some dealerships could turn up with a few surprises. Buy a cheap mk2 golf gti for about £200 and i'm sure VW techies could knock up a 1.8 20vt conversion in their spare time.
Dealerships do MOT's ;)
Alan Day VW have a mechanic, sorry Technician, with exactly that conversion :lol:
Edit to add - can image some poor r32 owner getting a phone call saying there is a 2 week delay on parts while they 'borrow' the engine
Edited by GiorgioGT
