20mm hubcentric spacers 4x100
hey up guys looking for someone who's runnin 15mm hubcentric spacers on there mk3 polo and wnts to balance the uneven wheel spacing on the rears....
basically am lookin for sum1 who wants ONE 20mm spacer for the drivers side to swap for your 15mm spacer...
that way there will be 2 more balanced polos out there and everyones a winner...
also of you are running 15mm spacers and its not rubbing, you will get away with the 20mm spacer on the drvers side as it is set in around 5mm more than the passengers side!!!!
  • Views 417
bump
bump
don't suppose you want to sell the whole set ?
