Mk2 front wing
How do you remove a the front wing on a Mk2? is it a case of undoing all bolts then flexing off with a screw driver or is it a massive project??
  • Views 1.9k
Not hard, the main bolts are along the top on the wing, and in the back of the wheel arch, fastening it to the A-pillar
Awesome! took my arch kit off today only to discover very little arch! after the metal all falked off as chunks of rust
Theres a couple of screws at the front under all the sealer.
