Mk1 0.9ltr carb
Hi
does anyone have a carb to fit the mk1 0.9ltr engine in good working order?
mines not, its using too much fuel and cuts out with no choke, I'm getting to the end of my patience with it!
Thanks,
Tom
  • Views 463
I've got one, but whether it's good or not I don't know as the engine has never run since I had it. Buy us a pint and pay the postage and it's yours if it's of use?
check the jets at the side of the carb,(13mm headed ones), give them a good clean,and also clean the jet underneath the top carb cover, then do your settings.
hope this helps(if you haven't done all this already).
