Debadging a 6N2?
How easy is it 2 do? The Polo Badge? The 1.4 Badge? and the Center Badge? Are they all stuck on with glue or is the VW badge fixed in place with clips?
The polo and 1.4 badge are really easy. Pour hot - not boiling - water on the rear window so it drips over the lettering. Then use a hairdryer over the letters to heat them up a bit, and then use a credit card to cut away at the lettering until it comes off. You will then be left with sticky gooey shit on the car, so give it a good scrub with some autoglym tar remover, and then polish the area to match the colour up. It's a really easy job.
The centre badge, i think, its slightly different because I think there is an indent it goes into, not quite sure on that one though. Ask someone on here who has changed their rear badge mate.
i figured as much, cos i jus wanna take off the Vdub badge and put the black 1 on..not sure..gunna wait and see who else replies on here..thanx 4 the info though..
