Help Removing The Center Rear VDub Badge on 6N2
As the title says need help lol
  • Views 1.6k
I used a wooden lolly pop stick
lift up the rubber surround and then just pullit off with the stick
then to get rid of the glue left on,
soak it in petrol and then heat it using a hair dryer and use a old credit card to scrap it off
  • 3 months later...
did you have any holes etc underneath the badge?
no holes mate. but there is a circle recess. i took mine of with hot water. softens the glue and then lift it off the boot with something
Heat The Badge Up With A Hair Dryer, Get Sum Dental Floss, And Put It On The Corner Of The Badge, Working Your Way Down, Pulling It Side To Side, You'll Be Left With Some Glue... Dont Put It In Petrol... Just Get Some T-Cut, Or Autoglyme Polish, And Polish It Out, Will Come Out Good As Anything! But Before You Do So, Make Sure There Are No Holes Under Is... And Thats A Bit Of A Pain! :) Hope That Helps!
i just shoved a body filler aplicator behind the badge until it came off lol!!
Heya
Just wondering how you got rid of the recess behind the VW badge on the boot?? I have taken the other badges off my 6n2 polo and would like to take this one off also??
i just used a credit card to get it off then i got some water scrubbed off the glue then polished it basic mod and looks good 2 :)
