Re-spraying questions
Hey, my drivers door is a different colour to the rest of the car so I'm planning on spraying it myself...student budget and all. Anyways I was wondering if someone could give me a few hints about what I need to do?
Do I need to strip the old paint off first?
Will I have to key the door to give them paint a good base? If so what grit sandpaper should I use?
How many coats of paint and lacquer?
That kind of stuff...
Any info would be greatly appreciated!
Alex
  • Replies 12
  • Views 1.8k
if the paint is sound but just wrong colour...sand it with 800/1000 grit wet...no need to remove the old paint , just sand until the shine has gone
base coat....enough until its even and covered(usualy 2-3 coats) then another 2 coats of clear if using pro stuff, aerosols prob need more coats
assuming its metalic...you might need to blend into the ajoining panels to get it right
you will get an awefull colour match with cans even having the paint matched painting a full panal without blending into the surrounding panals it will stand out
surely a back street bodyshop will do it on the cheap i know a guy that would do something like that for about £50 + paint
In my opinion some things should be left to the professionals, and paintwork is definately one of them!
I agree, if you diy, you end up making a mess of it and wasting your time and money. Its better to save up some cash and to get the job done properly :-)
You are probably right but as i am skint atm, and the door is starting to annoy me as it just ruins the car i think i might give it a go... afterall if it does all go wrong i can still take it to a bodyshop then.
i personally say grin and bear the annoyance it is giving you and get it done professionally.
if you spend money on cans of paint you wont have any more money and if that goes tits up it will look worse than when u started more than likely so it will annoy you more but u wont have any money atall as you spent it on paint.
The only way you can learn to spary is to spray? Right?
The choice is yours would a terrible (flaking paint, blotchy uneven coat, generally crap looking finish) look better or no worse than it looks at the moment? If so then give it a go, you might get lucky :lol:
Are you an art student by any chance???
(I take no reponsibility for any unwanted outcome!!!)
lol well for the price of a respray of the door couldnt you find a door that matched?
thing is it will take a fair few rattle cans to do a half tidy job if you have some skills
if it still looks rank the bodyshop will charge extra to sand off all the aerosol crap and re do it
id sand it all up and remove all the handles n trims and find a backstreet bandit that will blow it over
i wreckon you could do the door in at least two cans of paint, spray inside like a shed though!
If your worried about smoothness then coat the door in primer after you've sanded abit off the old paint. but then sand the primer only abit. laquer and polishing the door will increase the final result.take your time an dont get carried away with buy cans of paint.
another tip would be to t-cut the door first as it cleans it
sanding the door takes the surface of paint off so it'll be clean if you need to prime it flat it till it's smooth using 1500 paint flat again clear coat flat again then buff to a finish using a buffing compound and polisher :)
Cheers for all the replies. Looks like it will be going to the body shop afterall! I was in a bump today and now the car needs a lot more than the door sprayed.
