smotthing full mk4 boot
I'm wanting to smooth the full boot lid.
I'm planning on buying a second boot lid and smoothing it all inc the badg recess number plate recess and bot handle.
but if i take off the handle aswell will i need an alarm on my car so that i can have a boot popper on it?
please can you give me advise on how to go about smoothing all these bits.
cheers, ben
  • Replies 15
  • Views 2.1k
No, just buy a solenoid and fit it so it pops the lock open.
Most people have done it by cutting out the size of the badge/ plate/ handle recess in cardboard, then cutting it out of a sheet of metal.
Weld it into place, filler, sand, prime, paint.
That's the basic jist of it I think..someone who has done it will be able to go into more detail
cheers mate
gives me more of an idea what i got to do.
I've got central locking anyways so might just put an alarm in it aswll and then i can have an electric popper i recon.
chees ben
anyone?
hello?
any help here?
well if you can weld you'll be ok but considering you're questioning how to go about this makes me think you have fairly little knowledge on areas like this but if you wanna give it a go yourself then you'll need to weld plates over the badge plate and handle recess's, grind the weld's back, filler over the top flat that till you're happy with the shape, then a bit of stopper and flat that should do the trick
i know its a slight change of subject, but you know where sells stopper these days as cant find any! tried watering down filler but not that impressed with the effects!
lol my mate used his wires to his rear wiper to the (maybe even the rear wiper motor) to unlock the boot, just dont forget when you try and clear the back window your gona unlock the boot, lol
good luck..... oh yeah plate it in weld and flush with thin layer on filler, i would put a bit of sound stip on the inside (good tip) as to many novas etc drive around with cracked tailgates, lol dont want to be a muppet
well i got told if you just weld a plate into the recess that moistouer can get behind and crack the filler. so 1 of my friends sujested we cut out he recesses n weld the plates on from the back?
got an idea of what to do just neva done it befoe so help is very apreciated.
cheers ben
local place near me called autopaints stocks it!
newspaper and a bit of glue.....
:lol: i hear blue peter do a cracking diy guide for that method!
Paper maché (sp) bodywork :badgrin:
where do you reposition the numberplate? original place?
depends where you want it, putting it back in the original place would defeat the point of smoothing the plate recess wouldn't it?
if you weld a plate in..., you tap the weld down a little then if your good filler is only used around the weld area... no cracking...
