Rust & filler!
Anyone know what i use to get rid of rust, I've got loads round my arches and starting under my back lights, was wanting to rub it all down myself before putting it into a garage to get painted x
oh and what do i use to fill it aswell, was thinking about de handling my boot and smoothing it all, I'm such a skid but would rather do it myself its cheaper than a garage x
__________________
  • Replies 14
  • Views 2.5k
you'd be best putting in in the garage if you don't get rid of the rust it will just come straight back through a few months after it's painted
as for filling etc you need to weld plates then skim with filler to smooth and lose bits ;)
all i wanna do is smooth it all myself then put it into a garage for a full respray, I'm cheaper doing it myself x
but not when the rust comes through or the filler sinks and you need it repainting becouse your prep work wasn't up to scratch ;)
you need to sand the rust away until you see silver clean metal...use a dremel or something and keep at it until all the pits are gone
as for filling holes ..idealy weld a plate in , but if you want a go yourself use fibre glass paste
how do you it wont be up to scratch, what does a garage do that i cant, i mean c'mon how hard can it be to sand down some rust, all i need is the rite materials and I'm sorted x
stuff the filling ile leave that to a garage but defo wanna sand it myself x
Edited by DollyBurd
How good are you at shaping sheet metal and welding ? thats the hard part, having the tools and experience to do it. If you can't it's worth getting a sheet metal / panel beater in to do it.
Just sticking in a load of filler will do no good and defies the point of respray if it ends up cracking and falling out etc.
you need to grind ALL the rust out then use filler to fill the hole and uneven surface smooth flat and prime
it is not easy if it's not all gone it will come back and the paint shop won't cover it on the garentee
just a warning you need good tools and it needs to be spot on the prep work is the hard bit the paint is easy ;)
Depending how bad the rust it, but you'd need to grind it back to clean metal, then apply something like Kurust to it and then build back to shape with filler.
I spent six months restoring my mini, that was very rusty... but british car rusty, not german car rusty :shock: I had to cut away the panels until i was back to clean metal and either weld in repair sections, or make my own...
Mmmmm rusty;
:lol:
its hardly any rust, only round the back arches but it aint tones, ile leave the filling it sounds to hard, ile just rub the rust down and see how it looks, if i think its shady then ile just put it in the garage x
just wanted to save a bit of cash x
Any pictures of the rust patches?
if u going for a full respray it aint the time to save a bit of cash hun.. understand where you comin from but least if rust comes back they cant say "well u prept it.. we just put the paint on"
by all means go 4 it!! just make sure they give it the ok b4 paint that way u can go back if u have problems!!
got a 50p size rust bubble on my drivers side door n bodyshop can sort it.. but said in the long run it WILL come back. so I'm gonna get a new door...... when funds allow! lol.
david.
rear arches can rust from behind ;)
for the amount you'll save (i.e. not alot) i wouldn't bother unless you do the lot properly
ok ok, sounds as tho ile just be wasting my time so ile just put it into the garage to get done when its getting sprayed x
the pics of my car are in the members pics section, cant really see the rust, you can see a little under the back light but cant see the arches x
Hi Dolly,
not far from you PM me and i might be able to help you out a bit
