why is my steering shaking on motorway after lowering??????
hi i have some rh cups on my mk4 polo with 60m lowering i jus purchased some 195/45/15.
i have done the tracking and all the wheels have been balanced yesterday took on the motorway an the steering wheel is shaking on 60mph
why????
  • Replies 19
  • Views 1k
sounds like they aren't balenced right, i would take them back and ask them to check them
yea that what i was thinkin
going tomorrow
let us know!! :thumbsup:
what else could it be??
Tire Pressure? (Although they would/should do that when balancing)
Is it just at 60mph?
Does it go away if you speed up or does it get worse?
Are the centres balanced on the hub, spigot rings needed?
it happens on 60mph when I'm on 75mps its fine.
theres no spigots rings on the alloys are they needed????
Spigot rings stop wheel wobble because they locate the centre of the alloy onto the hub. So there's your answer!
That doesn't mean he needs them! He might have the correct center bore.
Are all the nuts tightened properly?
yep al tight. i bought the tyres from topgear. where can i get some spigot rings and what size???
You've got the wheels! You tell us! :lol:
Why are you so convinced you need spigot rings? What wheels are they?
they rh cups 15x7
with 195/45/15
laser tracking has been done
going to check balance tommorow
I've just rang top gear the left hand wheel is buckled so I'm going to swap it with the rear
also going to check the tracking again tomorrow
hope i dont have to pay for it
dont you remember thats how you bought it off ebay! one wheel was buckled!
your best bet, is buying an alloy off dubmeister.co.uk
it was'nt bought off ebay its was off clubpolo from kidd was told none of them were damaged. but the left alloys was
they are not spaced ? could be them if they are universal
left wheel was buckled but put it to the rear now everything is fine
