Another G40 Bites The Dust
Investigating a G40 shell i bought to build up....and found this :-(:-(
Its looking like another genuine shell is going to bite the dust :crybaby:
  • Replies 24
  • Views 1.6k
weld it up i say :)
Wonder what the rest of the underseal is hiding...
Shame that!
Take the under seal away from the chassis legs on most G40's these days and you will be shocked!
I've luckliy only owned one car to suffer excessive rot. That was a mk2 Fiesta :lol:
The car is clean and shiny on top (apart from a few rust spots) its a bit disappointing really as i thought it was a decent shell
cant u weld a sill on
Ouch, i was annoyed when i found a 5p sized rust hole on my chassis leg (looked like someone has tried to jack it up halfway down the car! nice.
That sucks man!
That's really not that bad at all. The worst thing being the inner part of the sill at the back as there are no repair panels for this so a bit of fabrication is called for. Certainly not worth scrapping it for though if that's all it is.
Was mean't to be a quick build up so allthough i could get a sill/sections fabricated I'm not sure wether it is worth the effort (also needs a hole in the battery tray plating and some other parts respraying)
S'only a days worth of welding, weekend tops! :-D
I'm not a welder :tear: I'll probably end up stripping it for bits and sticking the shell up for sale on its own
Edited by pettsy
Easy repair, dont scrap it for that. If you cant do it call a local mobile welder or bodyshop for a quote shouldnt cost much.
I'm no welder and I've welded a far worse polo sill! you not got any mates who can weld to a decent level? surely there must be someone on here who might be local enough to lend a hand?
That is hardly worth worrying about mate! Whatever G40 shell you get will have rust, sometimes in places much harder to repair then that. Would be a waste of another genuine G40 shell for that imo.
I've seen a lot worse, well worth investigating further with a view to repairing it.
I'm no stranger to working on mk3's, and yes i know theres likely to be rust, but i really can't see the point trying to save it.
As i said above, it was bought to house a spare g40 conversion i've got. I have another g40 i'd much rather throw money at than spend months getting this in a useable state!Theres a possibility i can get another clean genuine shell that needs an engine/box etc.
Edited by pettsy
Blimey its only a Polo shell! The fact that it is a G40 is neither here nor there - its only a few trim differences that make it different to any other Polo. In fact the only thing that I can think of that makes the shell itself G specific is the hole in the roof for the beesting aerial! Everything else is just bolt on/stick on/rivet on stuff.
If the G40 Polo had a very specific shell that was stiffer and had different suspension pick up points etc, then I too would say deffinately YES, repair/restore it.
Personally I'd never be 100% happy with a shell like that even if it was repaired to a good standard. It is almost certain to have rust elsewhere - the battery tray has already been mentioned and the body has spots of rust on it too. Take it to most so called "specialists" and they'll cut out the worst of it, patch it up with some vaguely correct shaped plates and bung another sill over the top of it at best. Thick coat of underseal and thats it. That is not the correct way of properly repairing a rotten sill section. PROPER restoration takes many hours and is hence very expensive.
If you can go out and buy another really solid shell (car) that is in far better condition then that is what I'd do. Saves all the arsing about and you can get on with modifying/enjoying the car itself.
I'm with pettsy, strip it and bin it. You never know pettsy, as its a G40 shell (Woooooow!!) somebody might buy the shell from you too. After all its got a 15mm hole in the roof!
The donor for my conversion I broke and scrapped, it had holes through the footwell and in many other places too, it was pretty bad and I've never seen one worse. As said, that sill can be repaired but you have to wonder about the rest of the car. I'd strip it and find a nice CL to pop the running gear in :wink:
Your giving up at that :o
Owning a mini as a project makes that look like nothing... weekend and that could be fixed and look good as new!
The point though B-Shaw is that its a Mk3 Polo, and there are 1000's of Mk3 Polo's out there with no rust whatsoever, so to justify the work it would need to be special, but its not!
I also own a Mini so I know what you mean, but when you can go out and pick up mint mk3's for £500 all day long, its not worth the effort! Whereas Mini's are a completely different kettle of fish, you can't get a scrap one for less than £500 unless you're a lucky bugger!
Yes, i probably could save the shell, but as i have another running g40 that could do with a few bits sorting I'm thinking this is a project that would take up too much of my time that would benefit my running one more.
Anyone want a cheap rolling shell?
well, I'm 99% sure it'll be getting stripped this weekend....writing the breaking post as we speak!
took mine to get the patch welded today and it turned out to be filled already and the hole was a size of my fist! funfun
getting it repaired today
how annoying! oh well!
Christ, does no-one get under their cars and check for signs for this kind of thing. After all you are preserving something that is getting rarer by the day.
I've had to weld far worse on my mk2 cl having only gone to a nightclass a year ago. I wouldn't trust just anyone anyone to weld on my car because it is easy to patch for an M.O.T rather than take your time and make it seamless. You should see my Caddy it's a total state compared to that.
The other guys are right, those repairs are all below the paint line so would be easy to asthetically hide with the correct repair.
Good luck :)
only bought it recently,if i'd have known it was this bad i wouldn't have bothered!
if anyone wants to save it from the crusher feel free to get in touch asap!
