striped, dashboard?
reet my mk3s striped to one seat and a dash board
i really want to take the dashboard out
has anyone got anyopis of this doen to a mk3?
and how would i put my clocks and stuff to the bulckhead haha
thanks jack
  • Views 993
Hmmm.... Haynes manual says (summarised by me):
- Unscrew mounting screws from below dash (location not shown or described, would guess far left and right)
- Disconnect diagnostic socket wiring plugs
- Remove steering wheel, steering lock, and combination switches
- Remove instrument panel
- Remove radio
- Prise away trim plate covering heater controls
- Unscrew heater control assembly and cables
- Disconnect switches, cigarette lighter, loudspeaker wires
- Unscrew facia panel lower mounting screws
- Open glovebox and unscrew the mounting screws inside
- Open bonnet and unscrew the 2 mounting nuts on bulkhead
- Lift away with help of an assistant and remove through passenger compartment, unclipping wiring harnesses from behind while moving it away!!
Hope this was some help thats all I can tell you as I haven't done it myself... Few questions though, noticed you've removed the soundproofing, where all is it? I've removed a few bits off the floor just experimenting (gona repaint floor soon), is it just the floor or is there any other places of soundproofing?
I've seen some of those pretty sweet little motorsport dial pods (like 30cm wide, mounted to the centre of the bulkhead at standard dash height) on trackday cars (mainly 205's) and they look fantastic, lightweight and practical.
little alloy rods either bolted, riveted or braised to a main wire covering alloy panel on the shell with a flat piece braised to the end to mount of the rods for the clocks so there in the std ish position if that makes sense :? if not i will try doin a piant drawin to explain it. I've seen it on a mini and it loked the bollox. :thumbsup:
Or you could buy the fancy Stack unit and say to people "they use these dials on Lotus'sss" lol
^^^ ok if youve got upwards of a grand to spend on clocks :lol:
the dash i was trying to explain wa sin a auqi blue mk3 turbo mini with a grey roof and blue centred split rims so if u find something on google looking like that see if there any interior pics and you will see what i mean
