MK3 Square
Might fit my front arch trims with my sill trims to my square this weekend, just wondering if the square has the holes along the sill for the sill trim to rivet/screw into?
Martin
  • Views 1.5k
Well I have a mk3 CL Coupe and theres no holes in the arches for trims to rivet to, I think I read that it was mk2's had this... I think on a mk3 there glued?
excuse my askin but wont a square look a bit random with no rear trim but fronts???
I know where you can get rear arch trims for a square ;)
I don't know about squares, but on the coupe, the holes are taped over at the factory and then undersealed over on the cars that don't have them fitted from new.
so do i ;)
that's why i'm fitting the fronts and sills so i can order the rears very soon :)
Yes mate the square holes are for rivets although i just used self tappers on mine so i can take them off ever now and then to make sure the body isn't rusting.
i found out today that unlike the coupe, the squareback mk3 doesn't have the taped-over holes along the sill for the sill trims to screw/rivet into.
Does anyone know a decent bonding product that'l stick my sill trims to my sills?
