Paint Advice
I'm thinking about painting my door handles and rear lights the same color as my car, my paint code is lb72.
Could anyone tell me a step by step process of how to go about doing this? from removing the door handles, to actually painting the rear lights. I've seen the lights painted on various topics on this forum, and they always seem to work okay, i've got no idea if it's legal or not, or if the light shows through properly, so if anyone could let me know, or give me pictorial evidence that'd be great!
Jack
EDIT: Also, the paint that my car has almost looks two toned in direct sunlight, it goes from a light grey to a dark grey. It may just be the way the suns hitting it, but if you look closely it looks kind of glittery, in like specks. Would the door handles/rear lights be EXACTLY like this?
Edited by Speno1988
  • Replies 8
  • Views 1.5k
lights are done with thinned down paint a few light coats then lacquer it and jobs a gooden you will be best to sand the lights with 2000 or 1500 wet and dry
with the handles just sand with 400 prime paint lacquer
Thanks mate, i see you're from chipsaway too, my uncle was telling me you guys work wonders on paintwork.. is there a chipsaway in Leicester?
more than likely try calling 0800 028 7878 that'll put you in touch with your local guy :)
Not had the handles out of a polo yet so cant tell you how to do that correctly.
How you paint the handles and lamps depends on what kind of paint you will be using aerosol or spray.
Give your tail lights a good key with a grey scotchbrite pad then rub out any marks with wet and dry from 800 up to 1200 grade.
For your handles give them a good key with a red scotchbrite and then a dry sand with 320 grade paper to remove any marks.
Thoroughly clean and degrease with a good quality panel wipe (preclean), then use a takrag (sticky cloth) to remove any dust particles.
Plastic parts are prone to becoming static as a charge is generated whilst prepping them, this can be overcome by wiping over with an anti static solution or a waterbased paint final cleaner.
Once you have the lights and handles prepared give them a light coat of a plastic adhesion, this can be purchased in aerosol cans and is clear so will not affect the lamps.
Once the plastic adhesion has been applied your handles can be primed, give them 2-3 coats drying each coat inbetween with a hot air gun or hairdryer.
Once your primer has fully cured out and is thoroughly dry wet flat with 1200 grade paper, now dry them off and repeat the cleaning process.
paint your handles first with a half to 3/4 coat give a heat as with the primer between coats, apply 2 full caots and check against the car once dry to make sure they are covered and look the same as the body ( there is usually a difference with plastic due to the chemical make up of it).
Your lights can be painted in several ways depending on what material you are using, if i was using a solvent basecoat i could either reduce the paint and wind in the needle to reduce the flow of paint then give them a couple of coats or alternatively add some of the solvent basecoat to some mixed 2K laquer and coat up till the desired affect is achieved.
If you are going to use aerosols apply several light coats. in both cases allow the paint to flash off (dry to the touch then apply 2-3 coats of laquer in the same way you painted your handles.
Allow your parts to dry overnight if possible then refit.
I would normally wet sand with 2000 and polish but on such small parts you might not want to bother.
And thats how a TRADESMAN does it, step by step!
^^ thats effing fantastic matey, thanks for the detailed reply! Now i've just gotta find a place that stocks the LB7Z paint. Shall i just got to a VW dealership? or risk buying online?
Your best bet would be a local motor factors or you may have an Autopaints International near you, there usually pretty good to deal with in my area anyway :smile:
I can't find an Autopaints near mine, ill just head on down to the VW dealership and see if they can supply me with the paint. I can;t find the LB7Z paint anywhere to buy on the net either, which is strange
www.autopaintsinternational.com should have a contact number so you can find your local store
