Handbrake Light
Hi All,
My handbrake light on the dash is permanently on (even when the handbrake is off) Any ideas how I can sort?
Rob
Either the swich on the handbrake is FUBAR or your brake fluid is low, start by checking the brake fluid.
Check your brake fluid :shock:
yup brake fluid is usually the problem, when i bought my polo thats how i found i had a leak! lol
Hi,
Checked brake fluid, all OK. No change in brake pedal height or performance of brakes...the light has now gone out & only comes on when you apply the handbrake (as it should). It must have been a gremlin..I will keep an eye on it.
Thanks for responses.
