Stop weld pin puller
Does anyone know if and where it's possible to hire/buy a pin puller for pulling out small bodywork dents ? Prior to paint prep I wan't to use one to get a few parking dents straightened out.
I can't see anywhere that sells them, I guess they are quite an expensive bit of kit too.
  • Views 1.2k
they're mostly 3 phase electric so not suitable for home use....nearest diy thing is a slide hammer that uses a self tapper if you can weld the holes up after wards
if they're just door dings...id just fill them
Sealey do a single phase one but its about £400
Shame the only one available is pretty expensive. Being a bit of a perfectionist with this project not throwing lots of bog at it, don't mind a final light skim of top stop though. Will ask around and try and get a loan of one.
