Solinoid boot & door poppers
i am hoping that when i get paid at the end of the month to smooth the boot apart from the plate recess and the door handles if at all poss, i shall buy a central locking kit but isthere any particular type i shall need to fit due to the poppers
also where can i get a solinoid from, and how easy is it to install a popper to blank in the dash?? and how would i pop my doors, buttons under mirrors??
any help on this topic would be much appreciated, and if any of you have done this yourselves any tips or pics or guides even would be a massive help
Thank you in advance
Dan
Edited by higgo
  • Replies 16
  • Views 2k
Interested in this also... so errr... what he said ^^^^ :-D :-D
alrite m8, wld look sweet with what u wnt to do ;):ninja:
I think its a necessity for what i want to do, it would be plain rude not to! :ninja:
i wanna do this aswell haha
cool, group buy on the parts we need anyone?! :lol:
ahah yeh defo guys we shl do group buy, i wnt this after the 29th tho cuz thts wen i get paid
:-D
There's a couple of ways of doing this,
The way i have done it is to use one of the outputs from my remote central locking kit to pop the solenoid, so i just use the boot button on my vw stylee key fob :D
You can find them on ebay,
Here's a guide of how i've set it up
http://www.dubclique.com/forums/viewtopic.php?t=77
hope that helps,
Haris
oh and the other ways are to use the button provided and mount it somewhere
OR
Use the rear wiper button as a trigger, this is ideal if you've already dewipered ;)
OR
Ideal untill your driving along and accidently pop the boot trying to turn you are wipers on!! :?
Is there any way of wiring it so that it will only work if the ignition is on?
Cheers for the info so far guys! :-D
lol how would you accidently flick your rear wiper on :lol: it's a button
Also this is why i said ideal if you got your car dewipered
Mine is de-wipered and on the 6N you turn the rear wiper on by pushing the wiper stalk forwards
the wiper stalks in yours are exactly the same as mine, you got a button at the end aswell though to keep the rear wiper on. But i can see how you can flick it on accidently now :retard: i still haven't done it, so you should be fine
mine goes through the wiper stalk and uses a TT filler flap popper to open the boot
mk4 golf ones work just as well..
and its OEM :D
There are several ways that you can do this. Did this years ago
For the handles, the easiest and cheapest way to do it is to use a witch underthe mirror. You and use relays to cutthe power in and out using outputs from your alarm system, via a relay. It means you wouldn't need central locking.
Another way it to get a central locking kit with seperate arm and disarm buttons to activate one door on arm, and another on disarm, again, via relays.
You can use the solenoids supplied in the kit, if cleverly connected, you won't need much pull pressure on the locks. no need for those mahoosive 40 tonne solenoids(they don't throw far enough anyway).
Boot can just be a simple switch.
i can supply most of what you need for this converion, if required.,
Good reply :thumbsup: Where is a good place to get a quality mk3 boot suitable solenoid, do you have them ?
I'm looking to get the alarm output to open the boot aswell as the rear wiper stalk (when the ignition is off), can it be done on the same relay ?
I can sell you a solenoid, but it will be the same as you would get from Maplin.
How will you get the rear wiper stalk to give you a signal with the ignition off? Won't work unless I am mistaken.
You could wire a seperate switch, through a relay. The alarm will probably give a -ve signal. There is also a wire that ges to ground when you turn the ignition off. use this wire, through a switch, to the -ve signal input on 4 pin relay(which I can also supply, if required), wire the relay in, and job done. To save you havingto feed the wires through to the boot, you could cut the feed wire to the rear wiper at the switch, and use that(not sure of the colours)
