rolled rear arches?
hey all
pretty much as above has any of you guys had your rear arches rolled on a breadvan?
just wanted to no if they kink out easy as i cannot afford respray
cheers
matty
  • Replies 16
  • Views 1.8k
just tap the arch lip in with a hammer then paint over with hammerite it'll be fine you'll break the paint anyway you do it but it won't be visable from the outside
If you go on www.vwcaddyforum.com there is drawings and information on how to make an arch roller using a vw scissor jack and a skateboard wheel along with a little bit of fabrication.
Spoken to a few of the guys that roll the archs for a living and one small tip is to heat up the arch before starting to roll it (not really going to help if you do it the butchers way and smack it with a hammer though)
we can roll arches. have a look at www.wide-wheels.co.uk
done a load of arches over the last few years and not had any complaints 8-)
u use a hammer and dolly as a bodyshop would ;) works the same way and you can get more clearance :)
Good work guys, nice to see someone posting what the know about for a change.
Takes more than 3 weeks to learn a trade!
IMO if you cant afford to do it properly, dont do it! you shouldnt need to anyway unless you are planning to run rims wider than 6j or use balloon tyres.
on a car of that age though i'm sure there are already a couple of chips / rust spots in the arches so it wouldn't matter obviously on a new car get it done and hope the paint doesn't crack ;)
cheers for all the help dudes :thumbsup:
Just noticed a bit about rolling arches in FAQ's
It's a brave person who messes with the rear arch on a Mk3 or mk2 breadvan because of it's shape. The jury is out on the ones i've seen in pictures. At the very least I would trim a small amount off the inner arch but wouldn't want to bend it up to catch water.
Every week someone wants to fit 7j wheels under a breadvan and we have the same discussion. Someone should sticky something once and for all. I would but I'm not good with offsets and I'm sticking with oem+ wheels.
i have 7j rims under the rear of my breadvan and its lowered -70mm also with a -7offset.
had to spend £1000 to get them under but they are there :lol:
lol the only way you will get them under
Top work on those arches!
Mmmmm.
bumper corners need stretching out to match imo
a grand well spent m8 looks schweet
see i'm a bit maybe with that, i know what you mean and i did speak the them about it but the edge of the bumper comes out to the edge of the arch anmd it just looks right, but when i have a LOAD of extra cash might just send it in for the hell of it
