any one want things powder coating
i can do powder coating on most things
especially car parts.
there are loads of colours to not just plain old black.
done a few things in red really looks cool.
all the items will be a lot cheaper than normal.
can do a delivery service to.
send me pm
i'm doing banded steels aswell.
  • Replies 35
  • Views 2.9k
pm'ed
maybe interested in this. Just gotta see what my plans are 1st.
Il be intrested in banded steels soon.
but I'm in reading
What would you charge for a set of 4 standard MK2 steel wheels to be coated up in black?
you should put up a small guesstimate list of prices going on size.... :-D
£60 for 4 steels m8
dan
but I'm in reading
we can do delivery
4 steels banded for 180 notes
13 steels banded to 7in and 8in?
bargin! cheers
i presume that i will have to privide my own steels?
Interesting... Do you have any pics of wheels you've banded?
also intrersted
and toby how many posts :o
aye pics would be good
:nod: :nod:
same^^ i presume they are all tested prior to sending out
Do you sand/bead blast the stuff first or need it sent pre-blasted? Got a few things in mind.
:shock: How cheap for banded steels?
would like to see your work tho...as would be trusting you with the wheels on my car,
only one of the most important things when I'm doin 70 down M1 :lol:
what standard are the welds?
what sort of tests do they get before they are sent out?
have you tried to balance them? how true are they when you try to balance them?
Edited by krisb
At the end of the day do you really expect them to be tested and balanced etc at £180 for a set? If they hold air and balance reasonably well, job done.
Obviously not the ideal method, but probably no more dangerous than running a 195/45 on a 9J wheel!
i thought they were illegal unless pressure tested or sumin, i dunno but sounds like a bargin tbh!
ha ha ha yeah too right or even a 185/50 on a 9j :lol:
not everything cheap is good. i was always taught that :lol:
but then again they could be ok
again these will be £180
dan
the steels will be dipped in acid to get the grime off the first and i can allso bead blast them to.
