Mk3 GT dash into a mk2 coupe
I am doing a GT conversion into my mk2 coupe and i wondered what is needed to get a GT dash in the car and if you can get them to fit well?? I want the car to basically be a GT with a mk2 shell. So i have the engine, engine loom, dash, clocks etc etc. Would i need the full rear interior loom from a GT or would any mk3 do??
I need to know as i would really like to use the GT clocks and they do not fit in the dash and no one seems to know if there is anyway of making them fit.
I have been told that with the GT dash there is issues with the steering column.
I know people have done this and i would liek to know more on the subject so any info is awesome. Plus if anyone who has done it before wants to earn some money and help me do it that would be even better!! :-)
  • Replies 17
  • Views 1.7k
i also would like info into doing this as i wanna fit a Mk3 GT dash into my Mk2 breadvan
I may be wrong, but i believe hoppygti may have helped katpolomk2 do this into her mk2 breadvan... might be worth asking them
You're mad mate!
Fuel lines will be off this weekend. Soz it wasn't sooner, been stupidly busy!
anyone knoiw any info on this as i really wanna Mk3 dash in the Mk2
can't be that hard surely, whats different?
bump - anyone have any ideas
I'm giving away a mk3 dash if anybody wants it
there is clearance issues on both sides and also around the steering column nothing a bit of trimming wont sort i was running mk3 doors and cards so ok at either side, looks like an easy conversion but its not, if your going that far might aswell fit the full gt loom you will need it for the pump anyway, as for dash i wouldnt bother i converted back to mk2 dash,
how hard was it dude
i have the Mk3 door cards aswell, am going to run bike carbs so will have separate fuel pump anyway.
whats different and whats the issue around steering coloum
sorry for being a pain but i'm always up for a challenge and i'm not shy about ripping my car to bits like, i know what i'm doin so don't worry about technical jargon,
do the dash bolt in as is and just require little things or is it a bit of a mission just to get it mounted
I fitted a Mk3 dash into my brother coupe S! It is not worth the hassle! The dash will fit fine. But if your intending on running the mk3 loom then u need to change the column switches which then means you need a mk3 steering column, which doesnt bolt to a mk2 unless you drill new holes or cut bits out of it and weld new bits in. Trust me mate stick with the mk2 dash!!!
i'm not going to use the Mk3 loom i'm going to adapt the Mk2 loom, i work with one hell of an auto spark and he said its easy enough to adapt like, thats what i mean, just need to know if i can get the thing in,
whats the issues around the steering coloum
if your using the mk2 loom then it shouldnt be too bad as you will be using mk2 column switches. You will probably need to trim some of the dash around the steering column so it clears but apart from that it seems to fit fine.
thank you very much dude you have made me day.
aslong as i can get it in and working thats all that bothers me, once its in i'll spend some time sorting it out and making it fit better,
just from the sound of it people were making it out to be a idiot of a job to get in,
so does it bolt in on the same mounts as the Mk2?
cheers
Will
In my brothers I have only bolted it in using the two bolts that go through the bulkhead as I had gotten very pissed off with wiring/steering columns etc by that point and had lost all interest lol! There are two mounting brackets bolted to the bulkhead which will only measure up to the mk2 dash. However the Mk3 has these aswell so you can probably take them from a mk3, bolt them to a mk2 and use them as mounting points. However I have not tried it so I cant guarentee it will work!
sound so a bit of fettling is required then,
cheers for your help dude
very much appreciated
Will
as far as i remember i welded 2 small side brackets on aswell if your running mk2 loom then steering column problem aint so bad just some trimming needed, trial and error is the only way but it gets annoying after a while as said before keep the mk2 dash so much simpler.
i don't do simple, i spent £1000 to get 7x13's on with a -7offset into breadvan arches so i'm always up for a challenge.
i'll get it in nicely, might take a while but i'll do it
