1.3 2G exhaust questions, please help?!
I need a whole new system for my 2G engine, only problem is i have a classic and so parts are different, my questions to you are,
What does this comprise of?
Downpipe, front silencer, rear silencer with no flexible pipe in the middle?
Secodn is, should my down pipe by a single or dual down pipe, i notice the HK engines have dual but not my 2G, is this correct and will a dual one fit mine and beneift it??
Cheers for you help
  • Views 716
The later 2Gs (with cat) have a dual downpipe which is essentially the same as the mk3. There will be some benefits to having a dual one, I'm sure. Usually the single downpipe exhausts come in 4 sections.
Downpipe
Flex
Middle Silencer
Rear Silencer
Are you looking at getting standard replacement parts or a custom made system? I got mine made at longlife.
