mk3 tunnel where the exhaust goes
as above that small metal brace that goes from one side of the tunnel 2 the other its just before the cat and is held on by 4 bolts is it necessary?? as my s/s downpipe rattles badly against it
  • Views 1.2k
Iv had mine off since i did my conversion (forgot to put it back on) Not noticed anything different except less scrapeidge on bumps.
thats ok then my downpipe is solid on it and it rattles like hell
Obviously it shouldnt be on the bracket, mine used to rattle on the exhaust clamp but abit of rotation sorted that.
Other then that check the bracket that supports the cat.
the part is actually a "cross reinforcement" to stiffen the chassis where the exhaust tunnel is and reduce flex which results in fatigue cracks/splits.
I'm sure if you didnt drive like a dick it would make no difference, or alternatively modify it
yeh I'm guna modify it i think ill do it 2moro thanks 4 the help people
