Boost return removal modification for Polo G40
  • 5 months later...
  • Replies 18
  • Views 9.5k
Oh, I can't see the pics in the link, can anyone else??
seems to be working alrite for me
Works for me in internet explorer, but not firefox.
  • 3 months later...
Link not working anyone shed some light as I'm at this stage with my engine
Guys, I'm gonna be changing ISP so this guide will be removed from my webspace, can somebody back it up and upload it to some other webspace? I don't wanna think my time making it will go to waste cos nobody can access it!
If u could mail me on mail@nick-lewis.co.uk once done that'd be sweet. 8-)
Cheers,
Nick
  • 5 months later...
Does it matter what kinda of spray grease u use....surely its normal oil lubing before the boost mod has taken place?
Edited by veedubboy
ptfe grease sticks to the components better than oil so lasts longer, you could probably use normal oil but you would probably have to hire an illegal immigrant to sit in your engine bay and spray the normal oil in every 30 seconds or so!!!!!
PTFE GREASE??Is that the gear Pitstop and G werks sell or is there something similar sold in a normal motor factors??
oops i meant ptfe spray! yeah the stuff pitstop sells
  • 4 months later...
Call me thick but what is the point of this mod?
Simon
  • 9 months later...
The point of it is that you only have fresh, cold air going into the charger and not a mixture of fresh and warm oily air that's been once round the engine already. Plus you get a cool whistling sound! I bought my G with this mod already done, does anyone know how much of a power gain it's good for?
On boost about 0 (zero)
sound!!!! try locking at this on you tube
(marham trackday polo g40)
stage4 charger tooth belt and all (160bhp)
Hi , i have some ptfe spray , where exactly do i spray it , link doesnt work
Step 5: Maintenance.
Periodically, you will need to lubricate the supercharger to ensure smooth running and avoid killing it! Pitstop Developments sell spray grease that is perfect for this task. Some people have stated they do this every 500 miles, and others every 1000 miles. I don’t do much mileage so will probably just do this once every month instead.
To lubricate the charger, take off your blanking plate then start the car, hold the revs at around 2k and spray the grease into the charger for 10 seconds. Refit the blanking plate, resealing with gasket sealant if necessary.
  • 7 months later...
cant see how this dose anything the only hose that needs disconnecting is the breather , to do away with that one way valve that turns into a two way valve under boost lol
the boost return can only help throttle responce as it coolered boosted air , and disconnected makes lots of noise .
if their is another reason for this some one tell me ?
What's the reason taking of the charcoal canister?
  • 8 months later...
shedding light on reason for mod, i had my car rolling roaded and inbetween 2 runs i took the boost return off and gained 8bhp, that was just removing the pipe from the throttle body, the whole permanent modification would probably do a few more
