Do these prices seem right?
Hi,
I had my wife's 1.4 cl auto serviced at an independent VW at the weekend (£94). The guy advised that I need the following done in the near future:-
Ribbed Belt (fan) - £33
Front brake pads - £81
Front wishbone bushes - £131
Distributor cap, rotor arm & HT leads - £86
Does these prices seem high? The prices are parts & labour.
Rob
  • Replies 11
  • Views 1.3k
What model is it?
They seem a bit high but thats due to labour too.
Have a look on gsf and you could probs get them a bit cheaper, and do them yourself :thumbsup:
What model is it?
It is a 6n, what is gsf?
erm, 6n polos have electric fans why would u need a fan belt ?...
He means alternator belt
i know ;)
the prices seem high, but there garage prices for you, if your confident to pick up the spanner and have a go your self, you could save.
i replaced dizzy cap, rotary arm, ht leads and spark plugs, and it cost me less the £50, then brake pads, you can buy pads for around £30 if not less.
your getting bent over with those prices! take it to your back-street-ill-pay-you-cash-geeza
Hi,
Rob
Here's an example of how I did it:
Distributor Cap = £8
Rotor Arm = £4
HT Leads = £15
Parts Total = £27
Time taken to fit = 30 mins
Cost of fitting = £free...easiest thing I have ever done. Garage must be charging in the region of £50 an hour and charging minimum of 1 hour?
The prices seem high, but when you take into account the cost of parts you're left with the labour...and labour at garages is always quite high.
I just bought new pads and disks and that was £87 on their own....so I'd prob. be looking at £130 to have them bought + fitted by a garage, no thanks.
personally I'd agree with the fan belt.
Everything else seems a bit high. I suppose the bushes require a bit of time but its still high.
The brake pads and ignition stuff though they have raped you IMO. Ignition stuff should have been £40 at most and brake pads £30 -£40 and they take 2 seconds to fit.
yep agree with tav, my dizzy cap, arm and ht leads were £27.50, and so easy to fit, was pricing up disc's + pads, and can get mintex ones for around £45 deliverd via ebay.
