BRAND NEW Audiobahn 3-Way components
i have a set of Audiobahn ABC6003v 3-Way components for sale. i allready have a set in my car at the front, and was planning on putting these in the back but its going to cost too much. Dont really need another set and the ones i have are MORE than enough for any audio enthusiast.
They fit perfectly in a polo 6n as there is space for the 6.5" in the doors, 4" ontop in the dash.
i payed £280 for them 6 months ago and they have just been sitting in my room.
i think £140 for the set is fair.
Audiobahn ABC6003V - TECH SPECS
6.5" 3-Way, Carbon Honeycomb Components,320 Watts Rms Model ABC6003V
Low Profile Component Systems
BASKET
The cast aluminum basket is particularly shallow to comfortably fit into 6 and 6.5-inch applications in domestic and import vehicles. The basket’s sturdy design decreases vibration, further preventing resonance from transferring to the cone and distorting sound.
CONE
Carbon lamination strengthens the cone and helps to keep its shape during operation. The stronger cone contributes to uniform movement, which keeps the voice coil aligned, lengthening the lifespan of the speaker and allowing it to handle more power.
TWEETERS
Audiobahn has chosen a silk dome tweeter to complement the accurate reproduction of the mid-range speaker. The result is a more natural-sounding reproduction, which is the primary motivation for purchasing a higher-end component system.
COMMON FEATURES
Carbon Honeycomb Cone
Butyl Rubber Surround
Cast Aluminum Basket
2 Layer High-temp ASV Voice Coil
25mm Silk Dome Tweeter
Surface or Flush Mount
Component Matched 18dB Per Octave
Crossover Network
Complete With Mounting
Hardware
ABC6003V
Audiobahn ABC6003V 6-1/2" + 4" 3-way Component System
6 1/2" and 4" 3-Way Component System
2 Layer High Temp ASV Voice Coil
Neodymium Tweeter Magnet
Strontium Tweeter Magnet
Chrome Plated Cast Aluminum Basket
Component Matched 18dB per Octave Crossover Network
Complete With Mounting Hardware
Power Handling:
320 Watts RMS
640 Watts Peak
Frequency Response: 30Hz - 25kHz Frequency Response
Sensitivity: 91dB
4 Ohm Impedance
20 Oz. Magnet
Edited by chimpy87
  • Views 628
absolutely crazyass ear piercingly loud bitches of components!
i need quick sale......120 quid........anyone???
Still forsale mate?
Whats the best posted price?
best posted price is £135 at the box is quite large and heavy
if not sold, il collect them with £100 cash. you got everything to install them with to?
Arran
