Rob's mk3 G40
Been meaning to post about my new car for a while, but been ridiculously busy.
After an unfortunate incident in my Qube at the end of November I had to find a new car.
As soon as Will, G40Will, heard about it, he very kindly donated his 1.0L Fox shell to the cause. With a condition I will share at a later date :ninja:
So we stripped the Qube, and started to fit the bits to the new shell. As it was without tax or MOT, we decided to take a bit of time (we normally do conversions in a day) and fit all the other bits I had collected over time, like GT rear beam, G-Laderseite ARB mounts etc. And fit things properly with custom brackets instead of cable ties. :lol:
Car started fist time, and went through the MOT without single advisory. A testament to James's skills.
Car is running a very safe map at present, very retarded ignition and lots of fuel, but still made 166bhp at the Club Polo RR day at the end of January.
Once mapped it will be over 180bhp, which with a weight of about 760kg make for a lot of fun.
And very upset M3/Porsche drivers. :ninja:
Spec
Base vehicle
1991 Polo Fox
Colour
Green
Engine
1272cc PY G40 engine from 1992 G40
PSD Full Blend ported VW G40 supercharger
Jabbasport induction kit with 150mm cold air feed from bumper
Ported Polo GT inlet manifold
G60 250cc green injectors
PSD 65mm tooth belt charger drive pulleys
PSD 4branch manifold
63mm stainless steel PSD exhaust system
Custom front mount intercooler with custom pipe work
Oil cooler
272/278 camshaft
Vernier pulley
PSD 51mm ported throttlebody
Full custom remap by PSD
Uprated slimline radiator fan
Lightened and balanced flywheel
Brakes
Uprated grooved 239mm discs
Raicam brake pads
Braided brake lines
DOT 5.1 brake fluid
Larger 22mm master cylinder
Chassis
H&R 60/40mm cup kit
G40 rear axle with anti-roll bar
Uprated anti-roll bar mounts
6x14 VW Castaletts with 195/14/45 Toyo T1S tyres or 7&8x14 Borbet T’s with 195/14/45 Toyo T1S tyres
Transmission
Sachs ceramic 4 paddle clutch with G40 ATV gearbox
  • Views 2.7k
I actually quite like that, tho the colour is a bit marmite for me. Who cares though, when the engine is as monstrous as your spec! Should be a poo-pants car with a remap hehe.
nice work, white borbets look great :thumbsup:
sweet car love the colour as its different!! keep up the good work !! :-)
I think the colour is awesome, although you are right it is a definitely a marmite colour. And I can assure you that as a passenger (ok a very nervous passenger who doesn't like not being in control) it is ALREADY a 'poo-pants' car :o
I can't wait to see what it will do down the stip :-D
Sal. x
