how to remove orange peel affect
ok i'm currently re spraying a panel in my polo and the end result has left me with a slighty matt and orange peel affect.
so i just need a quick tip of were i went wrong.
i'm thinking i should of wet sanded the paint before i added the clear coat. or even use a tiny bit of t cut.
bare in mind i'm doing this with halford spray cans.
any way i'm only learning so any help much apreciated.
i can pop some pics up if people are interested.
  • Views 1k
wet sand you clear coat back untill you have no low spots with 2000+ paper
than polish it back up
you should of flatted the paint down if you'd got texture in it before you clear coat, use 1500 to do this then you flat the clear coat down with 2000 and use a cutting compound and compound mop
you have a high chance of going through the clear coat if you didn't flat the paint so be carefull
cool exact advice i needed.
yeah i should of wet sanded the paint more then. i did alittle bit but i only had 1200 so didnt want to go too hard.
i did wet sand the clear coat with 1200 then i couldnt find my compound so just used t cut and then some meguires gold class wax.
if i used my orbital buffer i probably would of got a better result but cloth will do for now
