spare wires on the g40 loom
alright
just sorting the loom for my engine conversion
i have all the plugs wired up apart from two, and two raw wires ( engine side of things)
see pics, i know they might be difficult to work out from the pics
this is a long length of wire near the blue temp sensor and the dizzy plug
i think it could be the black temp sender wire? what is the length of raw wire for?
this is a green wire from the loom, that has been joined to a red wire, there is no plugs with missing wires, its just a raw wire, the surrounding green wires go to the dizzy plug and the above plug
  • Replies 11
  • Views 1.4k
top looks like a coil plug to me
Yeah thats a coil plug. Thats the trouble with old looms, often get hacked into for alarms and things :-(
thanks guys
do i just ignore that spare black wire coming off the coil plug?
any clue on the green/red wire in the second pic
the green/red one looks like it might have been spliced in for an air-fuel-ratio meter, can you see where the green wire goes to? Does it connect to a purple/violet wire?
That loom looks like a right mess I hope you didn't pay much/anything for it as it's going to cause you a lot of headaches I'm sure!
it came with my engine conversion
everything is present and correct and not messed about with the masking tape is my labelling, and i removed the looom tape on the shown section to inspect the wires
the only two parts i am usure / non-standard are the two parts in the above pictures
do i ignore the two raw wires now then
as i have no gauge or alarm system currently
thanks for your help
also are the g40 and gt looms similar because i have labelled some of my g40 loom using my old gt loom
Edited by BLACK6N_POLO
They are up to a point. Injectors, ancillaries and so on. But there's different sensor plugs in various places. For example the G40 has a knock sensor under the inlet manifold and the gt obviously has the Air flow meter.
does any one have a wiring diagram for a g40 engine loom
also is the mk2 polo non engine loom the same as a mk3 loom
There is one in the back of the Haynes Manual. :)
which is at the back of the garage under the stereo :thumbsup:
PS - check your email the haynes on pdf coming your way
e-mail me that shit brother from my mother
how easy or not is it to connect a G40 loom to a 6N , ie so u have working gauges and what not ??
what needs to be done ??
