how do i replace front indicator?
how do i replace the front indicators lense?
i have clear ones i want to replace the orange ones with
cheers
  • Views 908
The indicators are mounted on the same plastic bracket as the headlamps. They slide in to two 'runners' and then a flexible bit of plastic on the indicator lense hooks round the back of the mounting bracket to hold it in place.
So all you do is open the bonnet look down at the indicator and you should see the bit of plastic on the indicator lense that is hooked on the black mounting bracket. Push this clip out towards the wing and then just push the whole lense forward, outside of the car.
Then just get the lense off the bulb holder by twisting the bulb holder until it pops off. I always find it easier to connect the bulb holder to the new lense while it's off the car. Then you just line up the indicator with the two 'runners' on the black plastic mounting bracket, and push it in until it clicks into place!
edit: I'm blind
cheers!
Edited by xcore
