mk3 - mk2 front end swap
just been delivered the wrong wings for my mk3 coupe; to convert the front end to the twin headlamp mk2 grill will i just need the slam panel etc? its on my race car so there'll be no bumpers etc
any help will be appreciated it's nearly race season :)
  • Replies 8
  • Views 3.5k
arent the front ends physically longer on the mk3's?
doesnt appear to be wings fit fine its just the lights etc are wrong
i think the wings may fit but the mk2 definatly has a smaller bay... and the mk2 slam panel is spot welded on, and a different shape to the mk3 so this would be needed to mount the lights etc... :idea: and motor factors should have exploded diagrams of the car+panels and you should be able to work out what you need to mix and match... :p
I'm interested in doing the same has enyone got eny photos of the conversion,or advice?
will be nice to see pics when done
the mk 3 chassis is longer as it has sections added to the front of the rrails if you look behind the lights you can see where the mk2 chassis ends an mk3 starts
to perform the swap you need
wings
lower front panel
slam panel
bonnet
scuttle under windscreen/bottom of a pillars as there different to mk3
lights
grill
front cross member
think thats about it but not as easy as you would think quite a bit of welding
luke
NICE ONE THANKS FOR THE INFO IT ALL HELPS,COULDENT YOU SHAPE THE MK2 WINGS TO FIT AROUND THE MK3 SCUTTLE PANAL?
the mk3 scuttld doesnt fit the mk2 bonnet as it goes under neath but on a mk2 is level and the pillars are recesed for mk3 wings where as mk2 wings meet level.you could shape the pillars but the scuttle would look odd imo
luke
