K&N Induction kits
hey, I've been wondering whether to purchase the full induction kit from k&n for a while now, i have no other engine mods present. will it actually make any difference to my 1.4 MK4 8v??
what changes will i notice??????
thanks guys and gals
  • Views 877
It will just make a noise when you plant it. On a polo a 57i kit just sits ontop of the throttle body, sucking hot air in.This theoretically = less dense air = loss in performance.
The only induction kit that works is a BMC CDA.
If you cant afford that you would get better results by just using a performance panel filter.
Plus on my 16v it fuc*ed the throttle body actuator.
Bad times.
As stated above the K&N does basically sit behind the hot engine drawing in hot air= reduced performance. However, you generally need a cold air feed as given with the kit and a metal shield to stop the hot air from getting in. A kit without other engine mods is only there to reduced restrictive air to your engine. Thats about it (and a nice noise!).
For the daddy of induction kits you'll need a BMC CDA kit, which is more costly but doesn't have the problems stated above.
they do F all really apart from noise, the best ones like said cost you around 150 upwards and are propper filters...BMA CDA that you will get some performance gain
why dont you find out, have one for sale only £20. if you dont like it bin it
they do sit right at the back of the engine, but i bought a pipercross for mine from halfords for £20 (selling them out cheap as they are not going to stock branded ones anymore) it was for a mini cooper but i managed to find away to fit it, by taking the filter out of the airbox and then using the pipe to the cold air filter to mount it right near to the front of the engine with the cold air feed on it, and its probably phychiological buti would say as well as the noise its a tiny bit more responsive but nothing major. you could just get a universal one from motorworld/halfords and mount it like that, there only £20 try it take it back after you have had a tiny little go.
