8s & 9s on a 6N
i no these come up all the time BUT what sort of offsets should i be lookin at WITHOUT needing arch work? :-D seen a set which are 8x14 et15 + 9x14 et20. OR am i better off/safer with 7s & 8s? is so again, what offsets pls? Ryan.
  • Replies 21
  • Views 2k
Around 15
a 8" wheel will still poke out the arch you will need arch work with anything wider than a seven unless you are going to ride around at standard hight
You are definately safer with 7's and 8's as opposed to 9's.
8s all around at least man :unibrow:
aww man :-( so what offsets with 7s & 8s?
Get 8s all around. I'm running them at et20.
jus seen your new shoes post.. looks really nice. any clearance issues at all?
None atall. Scrubs a tiny bit with people in the back but not a lot, and is still quite low
yea it looks it :D what size tyres you running?
Edited by gameoner
you should be fine withe the sizes and offsets you said just need 195 45 14 all round
So he would need to get the arches rolled? to fit 8's front and 9's rear, or would he need more than just rolled?
Martin.
if you were trying to fit 10 x 14s at the rear what would be the perfect offset?
:smoke: hmm.. any got pics of a 6n running 8s & 9s widout arch work?
what offsets should i be lookin at for 8s & 9s then @ r4byy
Edited by gameoner
foxies running that set up 8 n 9s with no arch work
i had 16x8 and 16x9 with no arch work needed. they were et 30 though.
Cheers mate they're 195/45
ET 15 is my recommendation
na keep it 15 up front and 20 at the rear keeping it away from arch work :-D :thumbsup:
i ran 8's front and 9's rear my ex got pulled over for using it when her car was in for repair to go to uni in while i was working on it and not driving it until bodywork was done ;)
before arches
after arches
9x14's front and 10 x 14's rear :)
9's vs 10's same size tyres
fucking hell, 10s are too big i thing ill go for 9s, what et and dunlop size tyre for dirty stretch kid?
those 10s are rude!
can't remember the et but 225 - 45- 14 tyres
thanks for all the replys :D @ mbh69 them 10s look monstrous. lol. think i might go for 8's all round with staggered et's
