RUST
How does one get rid of this sh*t... and still keep the same colour paint, I've got a can of VW Satin Silver paint, i want the same finish though, help :D
  • Replies 19
  • Views 1.7k
the top pic bit looks like a bit of a bodyshop jobby to be honest pal.
depends on how much you love/want to spend on your car really, you could try and do it yourself rub down, prime, spray etc but if you have the cash go to a body shop.
Tommy.
Top picture is an old repair, you can see where the old filler has cracked. As for the sill you might get lucky by just fibre glassing it or after grinding all the bad rust out you might be lefted with a hole, this will need welding.
If it was mine i would take it a body shop and get it done properly. You are probably looking at £200 to sort it out.
the rust need grinding out first then treat it with krust or simaler
then filler and smooth, prime and paint :)
good look painting a door with a can it's hard enough doin silver doors with a gun and proper paint personally if your confident at the prep work i'd do that then leave the paint to the profesionals as silvers are one of the most difficult to paint and get a good match as the way the paint is applied makes the finishes different.
okay thanks for the replies, the top ones not an old repair, its where i was removing the bump strip on a rainy day, and slipped at the very last hurdle, ripped it off haha (cries inside)
I beg to differ dude look at the height difference between the silver and the rust... fillers, no? Plus there's a small pin hole to the right of the rust sure sign of fillers.
Silver never matches, trust me I paint for a living, and its a nightmare no matter what manufacturer, no matter what shade of silver you always have to blow/fade it out. painting edge to edge os a no no. so unless you have all the gear and have done it before I'd get it done by a a pro.
That rust is a nightmare, had a shite load of rust for a battery tray and took me about 6 hours of grinding, welding and cutting to get it all...
the disease
i hate rust :@
Well i bumped another car yesterday, pulled out too fast out of a parking space to avoid the tesco trolley boys, landed on this other car basically, totally shagged the side of mine, got a football sized dent, plenty of scratches to match. I've gotta see a pro for that now, so i'll get the rust done at the same time!
I got quoted £200 to do all the rust on my Mk3 which is more than yours dude, you could get it all done properly for roughly £140, if you know someone at a bodyshop then even better.
The little red car i was looking at has the same rust on the sills as yours only on both sides, slite bubbling on the rear arches and two scabs above the windscreen.
By the sounds of things its gona turn out to be quite expensive to fix the one i might be buying up.
£650 for the car and by the looks of it, 400+ to fix the rust.
£££££££££££££££££££'s
The rust now looks like this, after a collision, gutted.
ouch needs a bit more work now thats for sure
Bit of T-Cut to get rid of the scratches? :lol:
Had to be the first to say it...
Get it to the bodyshop for that wing would be a nightmare if you were to do it yourself, the door doesnt look bad I think they could fill that and smooth/paint it, but its not gonna be cheap!!
The cars being taken to the garage tomorrow at 2pm, costing me 250 to get it all repaired, including the rust patches being sorted, and the door handles coloud coded, is that a good price? I've got no idea how much i should be paying really
I'm glad some1 else has rust on this forum. Mine is alot worse than that on my mk4. I keep putting off sorting it out which is not a great idea.
very cheap that hope thay do a good job ;)
Yeah, sounds like a good deal mate. Lets just hope its quality work. Let us know how it turns out.
i had a small rust patch on my mk3 wing and then some idiot white van driver dented the other side, he paid for it to be repaired and the bloke who sprayed it charged him extra and sorted the other wing aswell :badgrin:
