G40 engine - £400
Near enough a full engine, the odd bit missing.
Comes with alternator, ecu, wiring loom, inlet, tb, dizzy, injectors, rail. Gearbox is a 4 speed unfortunatley. Missing the charger, fuel pressure regulator, rocker cover bolts and the rad doesnt look great
Also includes coilpack, and the rear fuel pump.
141k on the clocks, clocks are included with the engine.
Haven't had it running, so cant guarentee what its like. I have taken the head off today, there arent any melted pistons, it does turn over, but is a little stiff from being stood for a while.
£400
Collection from surrey.
  • Replies 17
  • Views 1.6k
whats a realistic amount of money to get this working?
in a 6n...
Dan knights got a charger for £130, could use your gearbox get an 8p for £50...
Could use your rad n that, then its just wiring really.
Give it a freshen up, plugs, leads, dizzy cap, rotor, head gasket, cambelt n water pump while its out, and should be ok...
Have to change the mounts for a 6n though dont you?
Dunno tbh, depends on the engine thats coming out. They go straight in the 1.3s iirc...
Not straight in no, need to adapt the O/S engine mount amongst other little modifications. Not too tricky though, I'd budget about £1500 overall for a 6n conversion.
You have PM.
Dan
If it helps anyone,
I have the G40 front looms and ECU spare that i would be willing to sell...
Jez
Cheers, but my engine comes with ECU and loom! :lol:
Oh yeah!! Not sure what advert i was reading when i wrote that up. Not to worry. Plus i've sold it now anyway - lol!!
Good luck with the sale..
Do these just fit straight in any mk3? I have a 1 litre and was wanting more power. Obviously need to upgrade brakes but do i need to upgrape anything else?
Also how hard is it to swap?
Yeah, straight swap in a mk3, pull the old one out with the loom n that, and put the new one in...
Will take £400
Took the head off today, pistons look ok, not melted, does turn over, but is quite stiff, does look like its been sat a while...
Would you take £300,i would come and collect
would you split? i need ecu, and valve on end of oil breather from pod on rear of block? and i need throttle body/boost valve?
might no some1 who'll have the engine for 375.00?
phil........give me a call......i know you're going away on monday, but my mate wants this engine, or at least wants to come look at it, with cash in his hand? When can we come, whats you are address? Is there a mate u could leave it with so we could come view it.......and can i just be certain, that all that is missing is the parts u've listed? Does it come with intercooler, boost pipes?
my number is 07921 910651 bTW
Edited by rixy
